It is currently Fri Jul 18, 2025 8:34 am
PostPosted: Wed Sep 13, 2006 4:44 pm
hey guys would someone be able to tell me if door higes are the same for top and bottom?
does it matter which one goes on top or which one goes on bottom..and how do you tell :?:
PostPosted: Wed Sep 13, 2006 4:47 pm
Yes it does matter.
It is stamped in them. Look for LL, LU, RU, RL from memory.
PostPosted: Wed Sep 13, 2006 4:54 pm
yup and just incase ur a little dense,
LU is left upper
LL is Left lower
RU is Right Upper
RL is Right Lower
PostPosted: Wed Sep 13, 2006 4:59 pm
yes... it matters and in case you didn't read the last two posts
RU = Right Upper
RL = Right Lower
LU = left upper
LL = Left lower
:P
and guessing by your sig pic, you seem to have attached your doors already
:shock:
PostPosted: Wed Sep 13, 2006 5:07 pm
no wonder the doors didnt want to go on properly :shock:
Some FIdiot put a LU and a RU on the Right side :roll: :twisted: :evil:
PostPosted: Wed Sep 13, 2006 5:08 pm
yep, but as you can see in the sig pic the door isn't shutting properly and on an angle :?
PostPosted: Wed Sep 13, 2006 5:11 pm
i thort the door was open on purpose! did u spray the car with the doors on, or are
u the goose that did it:?
:lol:
PostPosted: Wed Sep 13, 2006 6:07 pm
the car was sprayed with the hinges on. there were hinges on the shell when i got it, i just assumed they were the right ones.
PostPosted: Thu Sep 14, 2006 11:43 pm
to assume makes an ass out of u and me
PostPosted: Fri Sep 15, 2006 9:07 am
bugger, ey?
got any paint left?
PostPosted: Fri Sep 15, 2006 9:49 am
yea lucky we saved some :shock:
Gotta bribe the neighbour with beer to come over and spray the hinges now
PostPosted: Fri Sep 15, 2006 10:16 am
I have a drivers door that doesn't quite line up with the body at the bottom. Sits a bit out from the body. The door closes properly though. Could that be an incorrect hinge? Where does one find these markings on the hinges?
Users browsing this forum: Barkfast and 80 guests
