It is currently Thu Jul 31, 2025 8:21 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Tue Sep 12, 2006 3:53 pm
doogie: send me a pm if you are still coming and will send you my address and some contact details......
same goes for anyone that would like to come along.....
PostPosted: Thu Sep 14, 2006 5:46 pm
ok people...
i have bought the gaskets.... got a full engine set.....
the aviation glue
oil
oil filter canister type
heater bypass hose
coolant
have i left out anything...
? will i need new ball joints? ?
just to double check on the tools..... who is bringing what and what will i need to have...
cheers...
and hope to see you all soon
tait
PostPosted: Thu Sep 14, 2006 5:53 pm
What are the radiator hoses like ??????
If they are soft and soggy or swollen then they are not a good prospect - they never tend to seal properly again They need to be good.
They may last twenty years untouched but once disturbed its different story.
PostPosted: Thu Sep 14, 2006 5:54 pm
You won't need ball joints to swap the motor Tait, if they are in need of an adjust, you can do them any time, I would concentrate on the motor for now.
I will pop over on Saturday to see if you need a hand.......
I will PM you for address. 8)
Graham
Sir Alec! we are not worthy!
PostPosted: Thu Sep 14, 2006 6:34 pm
harvey69 wrote:
ok people...
the aviation glue
oil
heater bypass hose
coolant
cheers...
tait
I don't see any sausage sanga's and soft drinks and dancing girls on your list there :lol:
Seriously though, it looks like everything is there. I'll bring up some extra nuts and bolts, just in case some go missing. Who's bringing the Ball joint seperator and the Torque wrench?
Aaron
PostPosted: Thu Sep 14, 2006 6:54 pm
Mike, I'm still in awe of what you and the other folk are doing.
A suggestion - has anyone thought about metal clips to put back on the rubber boots when you put the drive shafts back in??? Cable ties will do, of course, but they aren't the right thing (or are they the other sort of uni. joint???)
Cheers to you all
Rod Image
PostPosted: Thu Sep 14, 2006 7:02 pm
Tait has a torque wrench but i will bring mine as well - Take no chances sort of thing.
I will also bring my ball joint separator - its a screw down type not bash the end out of a wedge type.
I think we have most things - Aaron - if you have a couple of pot joint balls then please bring them. Be a real shame to have one drop out and roll down a drain somewhere. *s*
Is someone bringing bringing a good trolley jack ????? - I am bringing my jack stands
A good set of pin drives for the rod change rawl pins would be nice also. I have some but they are indian cheapies.
PostPosted: Thu Sep 14, 2006 7:17 pm
Doogie will probably bring his trolley Jack, it'll be a goo excuse for him to show it off, he's very proud of it. I will dig thru the shed tommorrow and grab few bits and peices that will be handy.
Aaron
PostPosted: Thu Sep 14, 2006 7:29 pm
sausage sangas will be there dont worry and some coke.... :wink: dancing girls weather permitting.... :wink: :wink: :wink: :wink:
no problem about the jack as i have one here but if you have one u might aswell bring it as it cant hurt.....
i cant wait to get this started...
see you all soon....
will check this thread consistently for updates and everything else
PostPosted: Thu Sep 14, 2006 7:31 pm
I hope that at least a couple of those cans of coke will be made by Mr Toohey - especially towards the end of the day.
PostPosted: Thu Sep 14, 2006 7:33 pm
have cold tooheys extra dry platinums all ready to go..... or if your a burbon boy like me you can mix some jim beam up........
PostPosted: Sun Sep 17, 2006 4:34 pm
As of 11.30 am this morning Taits mini was again running
Intepid mini warriors basically had the engine changed and re-installed by 5.00 pm saturday and some time was devoted to tuning issues
Photographs here ;
http://s86.photobucket.com/albums/k91/c ... i_Rebuild/
