It is currently Sat Jun 21, 2025 11:25 am
Post new topic Reply to topic  [ 411 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 28  Next
PostPosted: Mon Sep 11, 2006 11:15 pm
looking good..ive seen chicken wire shoved into holes and bogged :lol:
Who is doing the frame/putting the engine in?
PostPosted: Mon Sep 11, 2006 11:18 pm
ive seen some chockers with flyscreen and bog :shock:
ugly ugly stuff :lol:
PostPosted: Tue Sep 12, 2006 12:28 pm
each to their own, i've been told bog should always be put on bear metal, because it stay's on better, then primed and finaly high filled.
either way, good luck with the resto :D
PostPosted: Tue Sep 12, 2006 4:40 pm
Enforcer is going to do the frame, just got to get it in there...
Life's a garden.... Dig It!
PostPosted: Wed Sep 13, 2006 6:50 pm
1970 mini K wrote:
i thought your ment to put the bog on bear metal....
you are, i thought the primer was just to keep the rust off really.. filler has the best life when applied to bare metal, then putty, block it all back, primer, paint.
Potato
PostPosted: Wed Sep 13, 2006 10:08 pm
the bog adheres better the a primed and scuffed surface. also bog retains water and in the long run bog+moisture+bare metal = rust.
if the metal is sealed first, this risk is eliminated. :wink:
PostPosted: Thu Sep 14, 2006 12:47 am
The old "bog" - polyester filler or "blade filler" can retain moisture,
that's another reason why we all use styrene based fillers these days.
Personally I find it sticks best to a properly abraded clean metal surface,
then prime & seal the moisture out with the top coat (that's what it's for) :wink:
PostPosted: Thu Sep 14, 2006 8:57 am
thats what i thought too.
so i took mine back to bare metal and put a temp layer of normal primer, found and bits that need a bit of filler, wiped off the primer with thinners, did any bog work needed then sprayed the panel with etch primer etc etc
PostPosted: Thu Sep 14, 2006 5:48 pm
well spending most of my time at the moment in a panel shop gives me the impression that you apply bog to a bare surface, which has been properly cleaned and not touched by your hands before the aplication
Potato
PostPosted: Thu Sep 14, 2006 10:46 pm
as am i... and as i said, they may do it differently in different parts :wink:
PostPosted: Fri Sep 15, 2006 9:18 am
whats the go with the roof??
PostPosted: Fri Sep 15, 2006 9:33 am
I would say full lenght webasto sun roof sherm :D
The body is seriously rippled are you panel beating and skimming with bog or filling everthing with bog, whats the plan?
Amazing concept.
Steve
PostPosted: Sat Sep 16, 2006 12:32 pm
The plan is to panel beat and skim with bog, as for the roof it is going to have a clear sheet of lexan in it.. Im also going to get a metal roof made up for it to give it another type of look
PostPosted: Sat Sep 16, 2006 1:05 pm
Go the Maybach glass roof $$$$$$$ just a few, should look really cool when done
Steve
PostPosted: Wed Nov 15, 2006 3:08 pm
I thought it was about time for a quick update.... The car is still at Enforcers and he hasnt started on it yet. But he is telling me that he should have it done by christmas, so ill aim for early feb. Ohh and i recieved my new brakes, just have to put them all together??
