It is currently Sat Aug 02, 2025 9:10 am
PostPosted: Sat Sep 16, 2006 6:45 pm
Now before you all laugh I must tell you I have no mechanic sense :P
Could anyone tell me what the big pipe, comming from head is on my engine and why it's there....
Thanks all Ian :D
I SAID DON'T LAUGH!
Ian - My Ve SSV Ute - Looking for a Mini
PostPosted: Sat Sep 16, 2006 6:46 pm
And yes it all needs a clean and coat of paint... on to do list :D
PostPosted: Sat Sep 16, 2006 6:50 pm
if it the pipe the has the four additional pipes connected and going into the head its part of the pollution gear....Laugh nar not from me :lol:
PostPosted: Sat Sep 16, 2006 6:54 pm
Yep, anti polution crap. You have the "smog head".
(an air compressor driven by the fan belt forced extra air to completely burn the hot exhaust gases)
O thought so :P The lovely pollution gear that does nothing:?: :?: :?: :?: :P
PostPosted: Sat Sep 16, 2006 7:23 pm
Resident Haemorrhoid
just plumb your Nitrus into it it will inject it right to where its needed :wink: :wink:
VVTIC :wink:
mtsmini wrote:
Tombo wrote:
PostPosted: Sat Sep 16, 2006 7:29 pm
:twisted:
i'm freaking out man!
PostPosted: Sat Sep 16, 2006 11:05 pm
VVTIC :wink:
que?? straight into the exhaust... :? :wink:
PostPosted: Sat Sep 16, 2006 11:08 pm
You know, to get a flame out the pipe. :twisted:
PostPosted: Sat Sep 16, 2006 11:14 pm
ahhh - afterburner.... very clever....
PostPosted: Sun Sep 17, 2006 12:29 am
you can rip it off if you want to clear the space out. you will just need to plug the holes with replacement plugs..
PostPosted: Sun Sep 17, 2006 8:10 am
Yuo can put some holes in it and play it like a flute
PostPosted: Sun Sep 17, 2006 10:13 am
or just bend the ends of the tubes over.... I've seen it work :shock:
PostPosted: Sun Sep 17, 2006 10:54 am
Uh huh, you simply cut them off half an inch from the head with a pair of sidecutters and use pliers to ftatten the remaining tube. Works well, but you slice your hand open when you work on the engine cos the pieces of remaining pipe are sharp edged.
Mind you they're not doing any harm as is, they're just in the way..
PostPosted: Sun Sep 17, 2006 11:15 am
You can plug 'em off with a 7/16" unf bolt, loctite it and cut 'em off. Same thread as main stud. i think those heads all have hard exhaust seats too ! Good for unleaded fuel!
62 Saxon Green 850
Clubby van
Users browsing this forum: Bing [Bot], Nev and 77 guests
