It is currently Fri Jul 25, 2025 11:44 pm
PostPosted: Tue Sep 19, 2006 9:16 am
hi all,
every time i hit a bump or am floating along on the wonders of hydrolastic suspension i get a sound like mice squeeking in the back (it's not mice i checked!) hehe
it's coming from the van rear doors or around that area any suggestions on what it could be and how to get rid of it?
i suspect it could be the locking pole things that go up into the holes when you close the door but have no idea cause it's hard to drive and lie in the back!
PostPosted: Tue Sep 19, 2006 9:20 am
Are you sure it's body and not suspension ? When the nylon cups that the suspension knuckles fit into wear they squeak on bumps like an old falcon . Failing that , trial and error with a little bit of grease on your finger on various contact areas till the squeak stops , just use a smidgen of grease and be aware of it when you open the doors so you don't coat yourself in it ....
PostPosted: Tue Sep 19, 2006 9:22 am
so some new cup and balls could sort things out maybe?
ill try the grease first though...
thank you sports850!
PostPosted: Tue Sep 19, 2006 9:26 am
If you think it could be the suspension , squirt a bit of wd40 or oil into the cup and take it for a drive to confirm it , but only if you're pretty sure it's coming from there otherwise you might wash more grit etc into it and wear them prematurely . Have the knuckles got the rubber boots on them still and are they in good nick ?
PostPosted: Tue Sep 19, 2006 9:30 am
im supprised to say, i have had both a squeeky van, and a squeeky old falcon(66)... i would have to agree with ian on everything he has just said!
PostPosted: Tue Sep 19, 2006 9:34 am
im not sure about the knuckles hehe ill need to look up what they are in my workshop manual and then ill get back to you!
PostPosted: Tue Sep 19, 2006 9:39 am
knuckles is just what I know them as , the little ball type thing at the end of the displacer rod that sits in the nylon cup , cup and ball sounds right .
PostPosted: Tue Sep 19, 2006 9:59 am
Possibly?
Or in our Estate,, a similar-sounding sound comes from the exhaust hangers where the metal strap goes around the tailpipe. Haven't had time to source a solution yet, though.
 Post subject: Springs
PostPosted: Tue Sep 19, 2006 6:16 pm
Loose or sagging helper springs :?: :D
Users browsing this forum: No registered users and 111 guests
