It is currently Thu Jul 31, 2025 5:45 am
 Post subject: Paint Stripping Supplies
PostPosted: Tue Sep 19, 2006 3:58 pm
What tools do you need to strip paint?
Wirewheels
Paint stripper
sand paper (what grades?)
primer
What else?
Also Trying to figure out how much of this junk I am going to need.
How long will a wire wheel last on a little car like a mini? How manys to buy?
How much Paint Stripper will i need? How many of the litrezz
How much sand papers to get
How much longer will i procrastinate for?
And how many more sentences will i write that the end will have preposition on?
PostPosted: Tue Sep 19, 2006 5:12 pm
also maybe think about:
Rust converter
Beer
Saftey googles/glasses
Dust mask
Ear muffs
Strip wheel (3M make them, they fit on your drill and chew through rust etc)
Scotch brite pads - the ones the wife uses in the kitchen...
More beer
Are you doing outside & inside or outside only?? I used about 3 wire wheels to do just the outside
PostPosted: Tue Sep 19, 2006 5:18 pm
+Glad wrap
-dust masks (can't drink in a dust mask)
+extra beer (to wash the dust down)
Get about 4 of those strip wheels (look like a thick black nylon scourer glued to a grinding disc) - will strip paint, bog, rust, etc without removing all Astro's remaining metal
PostPosted: Tue Sep 19, 2006 5:31 pm
long limbed clothing, paint stripper+skin=pain!
Angle Grinder with a wire wheel. A wire wheel lasts me about 4 hours work.
Sand paper of many grades make sure you get 360 and 1200 grit for finishing work and coarser stuff for cutting through.
Beer. Has that been mentioned
PostPosted: Tue Sep 19, 2006 5:39 pm
I've heard of stuff called "Naval Jelly" for paint stripping - anyone used it? Apparantly it's lethal if you get it in you, but it gets the paint off like stink!
1958 Morris Minor 1000 - "Nigel"
PostPosted: Tue Sep 19, 2006 5:54 pm
I have used and it ate all the paint really easily, and all the rubbers and the rubber gloves I was wearing. It was also impossible to clean up. It also dissolves rust but must be etched within 24 hours.
I didnt use it his time becuase it is so difficult to clean off. It combines with the dissolved paint to form a toxic caustic slurry...yuk..but effective
PostPosted: Tue Sep 19, 2006 6:18 pm
this is looking bad for my liver.... :o
must remember to keep my hootus clean too ..:D
PostPosted: Tue Sep 19, 2006 6:36 pm
naval jelly.....is that like toe jam but from the belly button?
If so that is gross, cant believe it melts gloves.
Mine just gets fluff in it.
PostPosted: Wed Sep 20, 2006 12:17 pm
maybe also a shower cap for you as well cushie....
don't want to damage those lovely locks of yours....
PostPosted: Wed Sep 20, 2006 12:47 pm
