It is currently Sat Aug 16, 2025 2:09 pm
PostPosted: Wed Sep 20, 2006 5:44 pm
hey
sooner or later im gonna get 13's so i was thinking something maybe different, the wheels are 13 by 6 drag ways with a bolt patter 100mm, so i dont see whats stopping me, i was also looking at those spider mags they stick on lancers,
PostPosted: Wed Sep 20, 2006 5:51 pm
sorry forgot to post the link
http://cgi.ebay.com.au/ESCORT-CORTINA-D ... dZViewItem
PostPosted: Wed Sep 20, 2006 6:46 pm
Umm, the Mini is not 100mm pcd, it is 4inch. If you force them you will break the studs.
PostPosted: Wed Sep 20, 2006 7:03 pm
are you sure, i could swear i saw somewhere written down it was 100mm, but still i will have em redrilled,
PostPosted: Wed Sep 20, 2006 7:20 pm
It has been written quite a lot, but that don't make it right! :lol:
Minis were invented before millimeters. :wink:
PostPosted: Wed Sep 20, 2006 7:26 pm
it's 104.somethingorother mm ;)
PostPosted: Wed Sep 20, 2006 7:31 pm
if i have them redrilled will i have any spacing problems
PostPosted: Wed Sep 20, 2006 8:50 pm
4 inches. A measurement I'm sure you're familiar with young Cush.
25.4mm x 4 = 101.6mm
PostPosted: Wed Sep 20, 2006 9:06 pm
buztoy i have just bought some cortina/escort mags for my mini and the stud pattern is different they almost fit though. these are them before they got redrilled will take pictures of them with new holes tomorrow.
if you do end up buying those mags you'll have to get the stud holes welded up and redrilled when i got mine done i just got them redrilled in between the old stud holes cause no one would weld up the old holes and redrill them[/img]
Cheers Dan
PostPosted: Sat Sep 23, 2006 4:10 pm
here you go better late then never my mags redrilled
Image]
im going to get some caps made up to fit into the bigger holes to cover them up so you can't see them
Cheers Dan
PostPosted: Sat Sep 23, 2006 5:20 pm
:shock: sorry mate but which holes are you running, if so which ones were ment to be welded up, i dont get it, the big ones look like they are the are set up for luggs, but the others are set up for stock nuts, do you need to change the studs of am i just ass about my face,
PostPosted: Sun Sep 24, 2006 3:58 pm
sorry mate should of explained myself better the holes i'm using are the little holes and the big holes were meant to get welded up but i couldn't get anyone to do that. so im just going to get t caps made up to plug up the bigger holes.
yes you will need longer studs
hope this helps if any other questions just ask cheers
Cheers Dan
