It is currently Sat Jul 19, 2025 3:12 pm
 Post subject: Front Subframe Mounts
PostPosted: Thu Oct 28, 2004 10:30 pm
Just want to know if anybody has a photo handy of how/what the subframe bolt setup should look like. FYI - mine does not have any bolts in there. No cause for concern if they're not there, it hasn't driven more than 5 blocks since I put the subframe back in.
PostPosted: Thu Oct 28, 2004 10:33 pm
Depending on the subframe, it could have either bolts or studs. Hydros had bolts, most dry cars here had studs & nuts instead. Why?? :?
PostPosted: Thu Oct 28, 2004 10:43 pm
Just amking sure we are on the same path. Sitting at front bumper height, front bumper removed. Looking at the 'holes' that are in the subframe. The front panel on mine was replaced and the whole is like the size of a 50c piece and the subframe whole about a 5c piece.
I think I have a pic Doc. Can you host for me if I can dig it up?
PostPosted: Thu Oct 28, 2004 11:13 pm
Sure- em to me and I'll host it. In the morning....[yawn]... :lol:
PostPosted: Fri Oct 29, 2004 7:34 am
If you'r talking under the front Bumper left and right....Bolts Please
You do have one each side :?
PostPosted: Fri Oct 29, 2004 9:32 am
speaking of mounts, ours aren't the same as UK ones are they? i've never seen these teardrop mounts before. Don't we just bolt them up here? Theres no gaskets or bushes anywhere are there?
PostPosted: Fri Oct 29, 2004 9:46 am
OK here's his pic- I shrunk it a bit from its huge size... :wink:
It's a late UK front panel.
I guess you could find some mounts, personally I'd machine some nice alloy spacers and thru bolt it.
<edit> re. my prev post- I thought you meant the TOP mount bolts.. :oops:
8)
PostPosted: Fri Oct 29, 2004 6:12 pm
Was thinking of fitting some tow hooks in there. I seen that done a few times. No that I intend for damn thing to be towed much I just like the look. No doubt Mr RTA person would consider them a hazzard.
Users browsing this forum: No registered users and 70 guests
