It is currently Thu Aug 07, 2025 10:23 am
PostPosted: Sun Sep 24, 2006 3:13 pm
i dont even want to know what they owe you for :shock:
PostPosted: Sun Sep 24, 2006 4:10 pm
a bit more... it looks strange with out the chrome bits...
PostPosted: Sun Sep 24, 2006 4:22 pm
Doesnt look to bad at all :)
PostPosted: Sun Sep 24, 2006 4:26 pm
Where's the rust?
This is looking to be a pretty nice unrestored 850, Michael.
PostPosted: Sun Sep 24, 2006 4:30 pm
willy wrote:
Where's the rust?
good isn't it...
it's looking pretty surfacey....
unfinished project, you mean... :)
there's a few tiny pits where the tin worm had a bite, but most of it appears to be on the seam itself.... lovely...
not sure what i want to when it comes to painting tho...
could just rub it back a bit and add a few more layers..
PostPosted: Sun Sep 24, 2006 6:07 pm
Just back on the angle grinder topic, I bought a supercheap $15 dollar jobbie and a black & decker for probably 3 times that much at the some time for the reason doc mentioned.
Anyway, guess which one has lasted better?
The bloody supercheap one. The black & decker had lots of wear in the bearing that holds the shaft that drives the disk. Lots of play meant it would vibrate the crap out of your hands with a wire wheel and destroy grinding or cutting disks really quickly (they bounce about and chip chunks off).
Took the black & decker back on Friday for a replacement, see how it goes this time. Probably should have upgraded to something better, or got my money back and bought a few more supercrap ones.
PostPosted: Sun Sep 24, 2006 6:46 pm
whinja ninja
whinja ninja
my pop used to swear by the cheap ones.
I don't know my name anymore.
PostPosted: Sun Sep 24, 2006 6:57 pm
i was told to get a cheap grinder and good quality wheels...
typical... i went to bunnings because i thought there'd be more choice...
so i got the dack and blecker... :)
PostPosted: Sun Sep 24, 2006 7:17 pm
Back and Becker?
PostPosted: Sun Sep 24, 2006 7:19 pm
What sort of wire wheel you using Cushy...I love the twistlock one on the grinder.
This is after doing both subframes and the rearend of the van with drill :roll:
PostPosted: Sun Sep 24, 2006 9:42 pm
*shrugs*
:oops:
it's shaped like a shaving brush... if that helps.. :)
