It is currently Mon Aug 04, 2025 1:41 am
PostPosted: Sun Sep 24, 2006 10:48 pm
Hi all, was wondering if anyone can tell me if there is a way to remove the alloy cone from the rubber section of the front suspension cones on an early mini. I have already taken them out of the subframe and did this without the compression tool (was a pain in the #%@* but got it done).
So anyway now i am rebuilding the front suspension and all that but cannot separate the alloy from the rubber... have got a set of hi-lows to fit.
Ps. i don't have the tool to compress the rubber...
All hints and clues welcome,
Cheers, Bryan
PostPosted: Mon Sep 25, 2006 7:23 am
spray around the top of trumpet with WD40, leave a while...
Then put the trumpet in a vice, go round it with a cold chisel and a BFH....
If all else fails, cut it off next to the cone, then split & remove the remains with the chisel, or dremel it. :wink:
PostPosted: Mon Sep 25, 2006 8:41 am
Sounds like a plan! Thanks doc.
Ps. why didnt i think of that? :roll:
Cheers Bryan
