It is currently Sat Jul 19, 2025 3:11 pm
 Post subject: Bonnett Pins
PostPosted: Fri Oct 29, 2004 10:05 pm
I'm after the mob that make the bonnett pins that has a 'key' like mechanism to undo it. From the outside all you can see is a bit of metal about the size of a 5c piece.
 Post subject: I think
PostPosted: Fri Oct 29, 2004 10:25 pm
I think your local revolution racegear shop has them.
PostPosted: Fri Oct 29, 2004 10:52 pm
I think they're a `Dzus' fitting.
PostPosted: Fri Oct 29, 2004 11:05 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i got a set of them ........... on my clubby
makka
PostPosted: Fri Oct 29, 2004 11:31 pm
are they similar to the ones you use for a flipfront? whats the best to use for a flip front?
PostPosted: Sat Oct 30, 2004 7:27 am
i got mine from the local repco.
The best ones for flip fronts would be the ones they use on drag cars that use a screw driver to lock and unlock. If they can hold a body on at 200+mph they should be fine for a mini :)
1974 Moke - 998cc
 Post subject: Two things
PostPosted: Sat Oct 30, 2004 9:49 am
You guys are talking about two diifirent things.
Tzus clips that Kev mentioned are a sping loaded captive locking thingy that you used a screwdriver or similar to push down on twist and lock into place. Alot of drag cars and flip front minis use them, They are good for holding stuff down but the shaft is not very long and probably would not be long enough to use as bonnet clips. The other ones Brad is talking about are proper bonnet pins but instead of haning and R clip or pin through the post like mine, they can be locked with a key.
PostPosted: Sat Oct 30, 2004 11:37 am
yep these are the ones i have.
1974 Moke - 998cc
PostPosted: Sat Oct 30, 2004 12:32 pm
Are bonnett pins legal?
PostPosted: Sat Oct 30, 2004 9:57 pm
Well Brad's car in above pic has been legally registered with them for a couple of days now! :lol:
PostPosted: Sun Oct 31, 2004 7:52 am
OKay here come the Question..I'm sick and Tiered of the bonnet...I want these on all four corners..What am I looking at here in work..
 Post subject: AAARRGH
PostPosted: Sun Oct 31, 2004 8:10 pm
Gafmo
Did this with my last mini and it had it's good point and bad points. Good is you can get easy access to motor, Bad is always having to lift the whole thing off for the simplest of things.
See pics here, for an idea on how it's done.
 Post subject: Bother
PostPosted: Sun Oct 31, 2004 8:23 pm
Bugger for some strange reason I cant get my ftp to work to upload pics. I have them here if you want thme I can email them to you.
PostPosted: Mon Nov 01, 2004 7:04 am
Cheers that would be Excelent if you could Email the to me and I'll post them for you....1310 came over yesturday and we had the same discustion....He mention some had used the same locks but fabricated the hingels so they took the same locks....So if you wanted to check the Oil and water..Normal Bonet if not take the hole thing off...Like this Idea also
PostPosted: Mon Nov 01, 2004 12:42 pm
i have 4 pins in mine, its really handy for engine work, but once, i forgot to do the pins up, drove down the road and the bonnet flew off and stuffed it, and the roof etc...
yeah :oops: my bad
Users browsing this forum: No registered users and 65 guests
