It is currently Fri Aug 08, 2025 5:53 am
PostPosted: Mon Aug 14, 2006 11:01 am
I just fitted another `Hella' LED brake light, this time to Barney.
Same as I've had on Ha-Ha for the last 4 years.
These things work great and are dead easy to set up. :D
PostPosted: Mon Aug 14, 2006 11:13 am
If you set it up for drum brakes,
should you set it up so only half the lights come on??
Or should they start to dim after 50 meters?
PostPosted: Mon Aug 14, 2006 11:16 am
No, you should put more than one brake light in! :lol:
PostPosted: Mon Aug 14, 2006 12:30 pm
Mate... that just cracked me up. Image
- Simon -
PostPosted: Mon Aug 14, 2006 12:38 pm
That's really bizarre. I've really been wanting to fit one of these lights, and here we are...
Did you just buy it from Repco or Super Cheap or similar?
Jonathan
PostPosted: Mon Aug 14, 2006 1:48 pm
I got this from Autobarn 3 years ago- I've just been slack fitting it.... :lol:
It's Hella, p/no 5239,
Watch it there are 3 different ones for different rear window slopes
. Each has limited angle adjustment.
<edit> this one would suit a Minivan, too. 8)
Repco or Supercrap can get them, but Autobarn had in stock. I think I paid $43 back then.
PostPosted: Thu Sep 14, 2006 2:05 pm
Just got my rear brake light, doc. Did you mount it at the bottom or the top of the rear window? Pics?
Jonathan
PostPosted: Thu Sep 14, 2006 4:43 pm
I mounted it at the bottom, but top would be OK except I have the thru-glass antenna there.
Before mounting. take the cover off and move the LEDs angle to the max.
Sorry no pics yet.
Connect to the green/purple wire on RH rear lamp. using the crimp thingy supplied.
Earth the black wire- I put a lug on back of the RH boot support cable top bolt.
Make sure to read the instructions.:wink:
PostPosted: Thu Sep 14, 2006 5:19 pm
If you mount it at the top be willing to not see any cars more than 50 metres behind you in the mirror - sort of like driving a mini van with the centre of the doors blocking your view. :D
PostPosted: Fri Sep 15, 2006 1:45 am
yeah i kinda thought about if it was at the top, it would block most of my rear-view view.
cheer, doc for the wiring tips. will post a pic when its all done
Jonathan
PostPosted: Mon Sep 25, 2006 5:02 pm
OK finally here's a pic of Barney's... taken at Gannon's Pk last week. :wink:
PostPosted: Mon Sep 25, 2006 11:56 pm
I installed mine today. Works beautifully. Comes on before the normal brake lights because it is LED, and it's nice and bright. I'll take a pic of it tomorrow.
I highly recommend all mini owners install a high level brake light. Adds that extra bit of safety our tiny cars need.
Jonathan
PostPosted: Wed Sep 27, 2006 6:05 pm
Here's mine. Nice and neat.
Jonathan
PostPosted: Wed Sep 27, 2006 6:10 pm
What colour is Barney Kev?
PostPosted: Wed Sep 27, 2006 7:30 pm
BRG, with a tipple of yellow added.
We had to match it again because the paint on LH door went crazy, lucky we still had the old tin with a bit left to match. :wink:
