It is currently Mon Jun 30, 2025 1:37 pm
 Post subject: Subframe specs??
PostPosted: Tue Sep 26, 2006 3:46 pm
Can anybody provide these measures?
I need them for my Honda VFR800 conversion. I'm getting ready to weld the engine mounts in but I need the measures to square everything up first.
PostPosted: Tue Sep 26, 2006 5:03 pm
Build a jig. In total we've done built five subframes. Each one of them different.
PostPosted: Tue Sep 26, 2006 8:29 pm
I agree with ^^^.
Building a jig will ensure everything is true.
Dan
PostPosted: Wed Sep 27, 2006 9:31 am
Yup, I already built the jig and the subframe is welded up.
The subframe is out of the jig now and I need to get the correct angles before I weld the engine mounts in.
This is why the front subframe mounting hole height is important to me.
Maybe if someone has a frame sitting on the ground they could take a quick measure???? :lol:
PostPosted: Wed Sep 27, 2006 9:57 am
I've got a spare one around the back of my place, DO YOU WANT TO COME AROUND AND SEE.
If you like i'll try and take some measurements on the weekend.
Dan
PostPosted: Wed Sep 27, 2006 10:20 am
It may be a bit expensive to fly over there. :D (I'm in the US)
But if you get a chance, I would REALLY appreciate it!
PostPosted: Wed Sep 27, 2006 10:40 am
Beau wrote:
that's a whole lot of motor right there!!
this one, right?? http://www.sportrider.com/bikes/146_0204_2002_honda_vrf800_interceptor/
Type: Liquid-cooled, 90-degree, V4
Valve arrangement: DOHC, 4 valves/cyl. shim-under-bucket/replaceable bucket adjustment
Displacement: 781cc
Bore x stroke: 72.0 x 48mm
Compression ratio: 11.6:1
Carburetion: Electronic fuel injection, 36mm throttle bodies
Transmission: 6-speed
VTEC kicks in at 8000rpm! :D bizarre how it takes up nearly the full mini engine bay, but fits in a motorbike....
I'm pretty sure angle 2 on your picture is actually 90 degrees, but maybe you should put it in your car to line up for doing the engine mounts, so you can make sure nothing else is in the way
PostPosted: Wed Sep 27, 2006 11:03 am
Yeah, mine is out of the earlier VFR without the VTEC. They actually run better and don't make as much noise.
Yes, the second pic shows the spring towers (or whatever) at about 90*. Unfortunitly the car is 3 hours away so test fitting and welding the engine mounts is a b*tch. I only had to cut out a 4"x 10" piece out of the right side inner wing to get the subby to fit though.
PostPosted: Wed Sep 27, 2006 11:41 am
that's a pain in the butt then!!
what have you done about adapting a differential and 2 driveshafts - given the bike gearbox would only have one output... unless you're going Front Engine / Rear Drive ??
I went and held a spirit level vertically to the crossmember of my cooper, which is sitting basically flat on my front lawn, you're gonna have to use some pythagoras here... maths, ewww
the spirit level is 100mm long, and I had to hold it 5mm away from the crossmember at the top to make the bubble centre- so the crossmember IS leaning back a bit
make sense?
PostPosted: Wed Sep 27, 2006 11:47 am
Yup, makes sense.
I have a BMW 2002 rear dif that I will be using. I have a build thread on the site somewhere. I'd have to do a search though.
EDIT- I also added another angle to the drawing above. It looks like the front mounting point is suppose to be 90*.
PostPosted: Wed Sep 27, 2006 11:59 am
crap Beau. I just went and read your posts about your build. Awesome man, awesome. If only we could do bike motors in Oz........
PostPosted: Wed Sep 27, 2006 12:00 pm
found it... neato :D nice and easy to put a long tailshaft in place of that diff... 8)
http://www.ausmini.com/forums/viewtopic ... ht=#261990
PostPosted: Wed Sep 27, 2006 12:02 pm
maybe everyone who has asked has asked to put it in the back..... and we might get away with it under the bonnet like that :?:
PostPosted: Sun Oct 01, 2006 11:24 am
One at a time Simon, one at a time...... two at most.
