It is currently Wed Jul 30, 2025 2:15 am
PostPosted: Wed Sep 27, 2006 8:23 pm
I have re set my tappets today, now the car seems to be running rough and weak at idle (could be various other reasons though)
What i think is interesting though, is that BEFORE i adjusted the tappet clearance , they all had roughly similar clearances, except one in particular.. which was had about 50thou.
And it just so happened that this was the strongest performing cylinder when i took the leads off each spark plug individually!
perhaps 15 thou is too small??
I was told i have the 'works' cam, max power at roughly 7.5k/ start to feel it start to edge in at 2.5k
what was the works coopers gap, should i run this too??
its a modded 1100 btw, and was going quite well through the gears before i readjusted
advice is appreciated :)
PostPosted: Wed Sep 27, 2006 8:32 pm
All valve rocker clearances are set to 12 thou. All models, except Cooper "S". are set cold with the latter set hot.
PostPosted: Wed Sep 27, 2006 8:36 pm
But when you have bigger cams and better ratio rocker arms you need to increase the clearance. I would probably try 16thou but you could just increase them all a little at a time.
PostPosted: Wed Sep 27, 2006 8:44 pm
Correct as per Morris 1100 once you increase from the standard cam the gap should be wider at the Tappets also
What method did you use to check the Gap...Mine is in the How to Section
PostPosted: Wed Sep 27, 2006 9:25 pm
just the rule of 9, same as yours gaf
PostPosted: Thu Sep 28, 2006 8:21 am
Good Stuff..did you check them twice or three times by chance rather than the once.
Open the gap to around 15 then and see how she goes then
Users browsing this forum: No registered users and 68 guests
