It is currently Sat Jul 19, 2025 3:07 pm
PostPosted: Mon Nov 01, 2004 4:56 pm
And if you want more `pub points' get Accord ones instead. Ventilated.... same diameter & basic caliper design.
Ping `animal' he is running them. :wink:
PostPosted: Mon Nov 01, 2004 7:01 pm
I would assume that there would be an aftermarket equivalent that would be even better then the standard accord rotor. Something from dba maybe??
PostPosted: Mon Nov 01, 2004 7:20 pm
Kev, big difference in the braking for the accord ones ?
I may consider it a future upgrade........
J
PostPosted: Mon Nov 01, 2004 7:34 pm
Same basic brakes as Civic, just ventilated. Probably overkill on a Mini- will take longer to warm up. You won't get the 230mm x 12mm solid Civics hot anyway.. :wink:
