It is currently Wed Aug 20, 2025 5:19 am
PostPosted: Sun Oct 08, 2006 7:03 pm
hey
well i can remember a topic that was "how quick can you remove an engine", i put this to shame, its taken 3 hours so far and all i need to do is this one little thing, see pic
the little rod that is cirled, there are little rods going through it they wont come out,
PostPosted: Sun Oct 08, 2006 7:05 pm
forgot to mention this is at the back of the tranny
PostPosted: Sun Oct 08, 2006 7:07 pm
Get a pin punch and drift them out, if you don't have a pin punch then a concrete nail with the tip ground flat will work (the right diameter of course). They are spring pins and I think they are stepped so will only go one way, if you can't remove one, try the other one.
regards
Daniel
PostPosted: Sun Oct 08, 2006 7:09 pm
i remember this bloody pin. you need something exactly the same size as the pin and punch it through.
we ended up just cutting it off :lol: cos i new i had a spare
PostPosted: Sun Oct 08, 2006 7:11 pm
An electric drill chuck key is what i used years ago, give it a good hit.
1974 Moke - 998cc
PostPosted: Sun Oct 08, 2006 7:23 pm
Put it in Reverse, then use a 3/16" pin punch to drive the front pin out.
If you don't own a PROPER pin punch, go buy one, or a set- before you slip with the BFH and hurt yourself... :lol: 8)
PostPosted: Sun Oct 08, 2006 7:51 pm
sorry guys never heard of a pin punch, im gonna drill the thing,
PostPosted: Sun Oct 08, 2006 7:55 pm
Good thinking, it should be a lot easier to remove with a broken drill in it. 8)
PostPosted: Sun Oct 08, 2006 8:36 pm
^^^ :lol:
It's a rolled pin..you use a pin punch to drive it out...you will need it to put back once you put the engine back in so it's worth saving ;)
PostPosted: Sun Oct 08, 2006 8:45 pm
Go to your nearest supercheap auto, say "Hi I'd like a pin punch set" and pay the person around $10... You will need it again to put the engine in with a new pin anyway...
PostPosted: Sun Oct 08, 2006 10:53 pm
yeah got him out, why cant i use 2 split pins
PostPosted: Sun Oct 08, 2006 10:54 pm
Cause your gear change will be even more sloppier than it already is...
PostPosted: Sun Oct 08, 2006 10:58 pm
great, my shifter is about as sloppy as a bulldog eating poridge, pin punch eh, can you buy new pins
PostPosted: Sun Oct 08, 2006 11:07 pm
n its not alot of fun when the pin falls out and your stuck in 3rd!!! on the main st :? :lol:
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Oct 09, 2006 7:27 am
Split pins are soft crap, even softer now made in China... :lol:
And always undersized.
The proper pins are a `roll' or `spring' pin, they are harder, and a tight fit so the linkage has less slack.
Do it properly- these pins cost peanuts... :wink:
Users browsing this forum: Bing [Bot] and 76 guests
