It is currently Sun Jun 22, 2025 8:26 am
Post new topic Reply to topic  [ 1864 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 125  Next
PostPosted: Tue Oct 10, 2006 7:16 pm
It's ok Tricky deans arms are not big enough to drive on a track yet :lol:
I can't wait to see how those coil overs handle, i went the traditional setup as you know cause i havn't heard many great things about the coil over setup. Would be good to compare and find out for sure 8)
Yea look what Brad started :lol:
PostPosted: Tue Oct 10, 2006 9:28 pm
Hmmmm I would really be intrested in the difference between the coil overs & the traditional...
Who can explain the pro's n cons to both?
Baracade
PostPosted: Wed Oct 11, 2006 8:04 pm
Oh, poor Dean......
Mind you when he gets on the straight he'll whip all our arses, pity he'll be a lap down (only kidding Dean!)
I basically went to the coilovers because of the tunability of the things. When you can adjust spring rate, spring weight, spring preload, shock compression, rebound and damping - that opens up a big field of variability for nearly an condition.
In terms of weight, they weigh less than cones and trumpets, or cones and Hi-Lo's (taking the shock out of the equation which is common to both). The springs wont sag (shouldn't), or deteriorate due to heat, cold, petrochem etc.
Plus, they look ace. I was going to marry them up with some competition adjustable sway bars, but they wont fit around the custom exhaust.
The good thing about rubber cones is that they are cheap to replace, unlike coilovers.
Tricky
PostPosted: Wed Oct 11, 2006 8:47 pm
Cones aren't cheap, officer.
PostPosted: Thu Oct 12, 2006 4:55 pm
OK who else is gagging for the next update??? Please Mr Tricky tell us more... please....
PostPosted: Thu Oct 12, 2006 6:52 pm
Mokesta - Thats just Tricky, my Dad is Mr Tricky.....
PostPosted: Thu Oct 12, 2006 8:19 pm
Chapter 9 - Some More Shopping.....
While I was busy shopping and buying parts in the UK (I wasnt in the UK, the parts were in the UK!), I decided that if I was going to send some parts back, I may as well send a heap of parts back. This should save me considerable amount of bucks by repacking it all together, and then shipping it as one complete item.
Sound idea. So, now that the front suspension components had been tied down and the rear as well, I took a closer look at the wheel geometry as a whole. On El Gato, the rear swingarms had been packed out quite a bit with shims, to get the tracking straight. After measuring the tracking with a long straight-edge, I realised that the tracking was anything but straight. To fix the problem, I needed a set of rear tracking brackets.
Now, there are a heap of rear tracking brackets out there. I chose a set from Minispares for the following reasons:
1. They were tracking and camber brackets in one
2. They were black, so they wouldn't be noticed under the car
3. Ease of on-car adjustment
4. The price was good
So, I parted with AUD$102.12 (including duty, GST and freight) and put the suckers in the crate along with the rest of the stuff.
Here is what they look like:
Just having your rear wheels out of track by 1 degree is like carrying an extra 20kg of dead weight in the boot!! I wanted the alignment to be absolutely spot on - zero deviation. Also, while doing track days, I can easily with a spanner, dial any camber adjustment I want. Typically, I would run 3.5-4.0 on the front, and 2.0-2.5 on the rears. V8 supercars run 6.0-7.0 degrees.
I also decided to buy a quickrack steering rack. These are available here in Australia, and I priced one from Karcraft for $260.00 plus freight from Sydney to Brisbane. I checked out the prices in the UK, I shelled out AUD$179.40 (including duty, GST and freight) from the good people at Minispares, and they sent it along to the freight forwarder with the rear brackets. The quickrack will reduce steering lock to lock from 2.8 turns (standard mini) down to 2.2 turns. This may not sound like a lot, but when you are belting round a corner and the rear steps out, you want the shortest reaction time possible to put it on opposite lock. It may mean the difference between a filthy power slide and backing it into a wall.
Here is a pic of the rack, it looks the same as the standard rack:
But BE WARNED!! There are people out there I am sure that will sell a rack, any rack and claim that it is a quicrack. There is an easy way to identify if it is, or isnt. This label reads K022RH. The K stands for the mini model, K-series (Austin, Morris, Leyland - not Rover) and the 022 stands for 2.2 turns lock to lock. The RH stands for right hand drive (Australia). Do not buy a rack unless it has this factory label, and especially if it isnt RH drive, it just wont fit.
Now that the steering and suspension was all out of the way, it was time to turn my attention to the item I thought would make the clubman really stand out from the crowd. A body kit. I had been in consultation with Zeemax and Custom Autofashion for a while, getting the good oil on there respective kits (they are identical BTW, and each claim the other stole the design!!). I eventually went for the Zeemax kit, even though it was some 200 pounds (yes pounds!) dearer. I had talked to Les ?? at the Mini Muster and he said he thought the Zeemax kit was good quality.
I bought the whole bodykit, front spoiler, rear spoiler, four flares and two side skirts (8 pieces in all) for AUD$1,440. Add in duty, freight and GST, the whole shebang came to AUD$1,810. I must admit though, when it arrived home, I was deeply disappointed with the fit, finish and quality of the kit. It was, in a word - crap!! The kit was out of alignment, diidnt fit well, was too much fibreglass and resin in some areas and not enough in others, and, it had a crack in the front spoiler.
Here is the front spoiler during test fitting:
Three-quarter shot:
Side on showing the flare (this is the good side BTW)...
And finally the rear:
Even before I had bought the Zeemax kit, I knew I was going to modify it in some major way. Since the above pics were taken of it, I have cut out a huge area for the front intercooler, and will modify it further to incorporate a pair of 100mm driving lights, and cold-air induction on either side (passenger side for 4EFTE, drivers side for B16/D16 Honda). The bottom brake duct inlets will remain. The rear spoiler likewise will be modified to fit one reversing light and one fog light incorporated into it, and the shape will be a bit more modern.
Once I have modified them, I will pull a mould off them and make others on order. So, if any of you are thinking of buying a bodykit in the near future, please let me know. It will be a damn site cheaper and better quality than Zeemax!!
Well that concluded the shopping spree in the UK - substantial savings were made and parts not available here in Oz obtained! Oops, one more thing to get whilst I'm shopping in the UK - special brake lines for the Metro's. Since metro's are common in the UK, getting the braided brake lines was a piece of the proverbial. Huddersfield came to the rescue with a set from HEL (who make brake lines for Ferrari and Maserati I later found out!!). I forked out AUD$74.75 for a complete set. They threw them into the box with the coilovers, and sent them off to the freight forwarders.
The brake lines:
Next in Chapter 10 - We go shopping for wheels and tyres and other bits in Oz (why should the UK get all my cash??)
PostPosted: Thu Oct 12, 2006 8:37 pm
Good stuff, i love shopping 8)
You'll find all Oz mini's and UK MK1's have a 2.2 rack., on the quickrack the ratio is different though..
Later racks were 2.7-8ish...i think the ratio is still the same with just more lock but not sure..
You will need to change your steering arms to the later MK2 arms to suit that rack as well :)
you're arms are going to be like Deans with an even quicker rack and those 13x7's :lol:
PostPosted: Thu Oct 12, 2006 9:26 pm
Here comes the good bits............
PostPosted: Thu Oct 12, 2006 11:15 pm
Nice arse.
Dan
PostPosted: Thu Oct 12, 2006 11:18 pm
Not as hot as betty's ;) :lol:
PostPosted: Fri Oct 13, 2006 12:17 am
i want flares like are on the zeemax kit... are they similar to sportspacks? :?
PostPosted: Fri Oct 13, 2006 12:22 am
yeh but betty's arse doesnt offer two (exhaust) holes now does she? :roll:
Inconspicuously Conspicuous
PostPosted: Fri Oct 13, 2006 1:54 am
She only needs one hole...
Do you have two things to insert into the two holes at the one time ? :?:
PostPosted: Fri Oct 13, 2006 9:16 am
^^ :shock:
Bob Slattery
