It is currently Sat Jul 19, 2025 10:48 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Nov 04, 2004 10:08 am
sc.. "a cop who knows " ....what are the chances? :)
and then i'll just stick my 3.5's back on.. easy...
doc there are separate laws for hot rods... :? go figure
PostPosted: Thu Nov 04, 2004 4:13 pm
Make Your's into A Hot Rod Then :shock: 8)
PostPosted: Thu Nov 04, 2004 6:45 pm
i'll just drive without the bonnet on.. ;)
PostPosted: Thu Nov 04, 2004 6:55 pm
i have a dream........a dream that one day i will drive around in a rat-rod mini
seriously....i reckon that'd be sweet as.....matt black, or maybe red primer, no grille or chrome bits and REALLY wide widened steelies with white walls and a monster donk.... 8)
play 3d car games for free
PostPosted: Thu Nov 04, 2004 6:59 pm
YER.,..What officer...its a Hot Rod :shock:
PostPosted: Fri Nov 05, 2004 12:11 am
The fine print for widened rims is : you cant CUT the rim, insert a band, then reweld them. Wide steel rims must be unmodified and uncut, for them to be okay ( which would make them technically "not widened, just wide rims" )
It is said that modifying a rim compromises the strength of the rim, making them unsafe and therefore illegal.
PostPosted: Fri Nov 05, 2004 12:17 am
But not Purposed Built
PostPosted: Fri Nov 05, 2004 12:33 am
um...huh?
Im guessing you mean... a rim made to your very own specifications?
I'm not sure about custom made rims..... i guess if they are made the required size from 1 piece of steel it would be okay..... but if you made special rims by chopping up a rim and adding metal to it, it would be illegal in South Australia.
Custom made wheels would most likely need to be tested before they are approved too. Any evidence of seam welding around the rim (as in widened stocky rims) will make them illegal.
PostPosted: Fri Nov 05, 2004 6:20 am
Somebody got a link?
A hot rod is just a radically chopped/modified car usually- surely a modified Mini would fall within this net. Or is it model or age specific?
PostPosted: Sat Nov 06, 2004 7:25 pm
here's some stuff from transportSA...
http://www.transport.sa.gov.au/pdfs/personal_transport/light_vehicles_pdfs/Info_bulletin_3.pdf
( for those that haven't seen it in the mods section :) )
PostPosted: Sat Nov 06, 2004 7:56 pm
So reading that I can run a tilt front and wheel spacers!
PostPosted: Sat Nov 06, 2004 8:18 pm
Also reading that you can fit Honda or whatever brakes (but better than stock) and no mention of Engineers reports needed... 8)
<edit> as long as car is 77 or earlier.
PostPosted: Sat Nov 06, 2004 9:20 pm
1100 ....if you live in sa... :)
doc... indeed.... but i'm not sure teh machined 7.9 inches would be allowed...
PostPosted: Sat Nov 06, 2004 9:23 pm
My reading of their tea leaves is.. it is referring to disc thickness, (min is 10 for Hondas) not to modifying the diameter. :wink:
PostPosted: Sun Nov 07, 2004 11:04 pm
In that document on SA regulations.... tilt front yes, but NO wheel spacers EVER
Users browsing this forum: awdmoke, Bing [Bot] and 104 guests
