It is currently Sat Aug 02, 2025 9:35 am
PostPosted: Tue Oct 17, 2006 3:01 pm
I'm currently taking apart my '71 Mini K as I'm planning on taking it down to bare metal for a restoration.
I'm in the process of taking out the door cards and after removing the three screws that retain the door latch housing and removing the window crank, I can't seem to get the door card out.
I don't want to damage anything, so I was wondering at this stage, what is the proper way to remove the door card? I see that the door handle mechanism has a rod that connects to the latch mechanism as does the door lock mechanism. Do both of these rods need to be disconnected before you can remove the door cards?
- Merrick
3/71 Morris Mini K
PostPosted: Tue Oct 17, 2006 3:07 pm
Ok , threw me there for a bit , you're talking a mini K with the clubman doors (black flat pull back handle in a chrome surround rather than a door handle that looks similar to a window winder) aren't you . The interior door handle is surrounded by a black plastic trim that comes apart into two bits , with that removed the door card will fit over the door handle without needing to remove the handle from the rods . There are a couple of push in clips on the door card (not sure where from memory ) and once you have removed the window winder and have the door handle unscrewed , start gently prising the door card out from the bottom till you see where it's stuck with the clips , then put the flat of a large screwdriver behind the clip area and gently pop it out of the door . keep going till it's only held in by the top fold of the door and then ease it over the door handle . Also check if a previous owner has put screws into the door cards anywhere .
PostPosted: Tue Oct 17, 2006 3:25 pm
Thanks! I see what you mean now regarding the door handle housing. It's in two pieces that come apart vertically.
- Merrick
3/71 Morris Mini K
PostPosted: Tue Oct 17, 2006 3:44 pm
i start from the middle of the door with both hands, balloning out the center of the trim. as sports 850 said make sure all clips are prised out.
Users browsing this forum: Bing [Bot] and 97 guests
