It is currently Thu Jul 24, 2025 10:42 am
 Post subject: Improving the dry ride
PostPosted: Tue Oct 17, 2006 8:22 pm
Slow-Po
Are there any sure fire ways of improving the ride on a dry Mini? My suspension doesn't look like its had much attention other than hi-los, and I would like to soften the ride a little.
I figure I've got hydro envy. :)
PostPosted: Tue Oct 17, 2006 8:26 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
save your money and buy some smoove rides from the you kay they are a actual spring's and not rubber cones ...
other wise look for some rear dounuts they cop less stress when in use
makka
PostPosted: Tue Oct 17, 2006 8:30 pm
New rubber springs will make it ride better and softer.
PostPosted: Tue Oct 17, 2006 8:37 pm
Alex Moulton's Smootha rides ARE rubber cones, but different profile to the usual.
S-Racer in the USA makes the metal springs... if you can call something with less than 2 turns a spring. :lol:
PostPosted: Tue Oct 17, 2006 8:41 pm
Have you ever heard about the trick of altering the rate of the rubber spring with a ½" drill bit. :twisted:
PostPosted: Tue Oct 17, 2006 8:44 pm
Slow-Po
Thanks guys, so the consensus is to go for these
http://www.minisport.com/classic-mini-s ... oduct.html
as opposed to these
PostPosted: Tue Oct 17, 2006 8:45 pm
Improve the dry ride? make it wet :lol:
PostPosted: Tue Oct 17, 2006 8:52 pm
Yes but never had to do it, as I have proper hydrolastic... 8) :D
PostPosted: Tue Oct 17, 2006 8:58 pm
Or get the cones from a much later mini , apparently after 1978 , English mini's had a slightly softer compound rubber in the cones . My 78 South African mini had them and was nice while not adding too much extra body roll .
PostPosted: Tue Oct 17, 2006 9:04 pm
Slow-Po
:lol: I've got a 1988. Maybe I should just accept it as it... :)
PostPosted: Tue Oct 17, 2006 9:05 pm
Nahh , put aussie rubbers in it and then see if you have anything to complain about :lol: :lol: :lol:
PostPosted: Tue Oct 17, 2006 9:08 pm
Meh... just convert it to hydro, like I'm doing the Clubby van... :lol: 8)
PostPosted: Tue Oct 17, 2006 9:10 pm
Slow-Po
How hard is that? Doc, are you documenting this conversion?
PostPosted: Tue Oct 17, 2006 9:13 pm
The later rubber springs are softer when new but after all this time they will be as hard as any others.
New springs will be softer but they do not stay soft forever.
Users browsing this forum: No registered users and 118 guests
