It is currently Tue Jun 24, 2025 1:31 pm
PostPosted: Tue Oct 17, 2006 7:57 pm
I have just had new hinges fitted however the top drivers side one has come lose
now i understand how this could happen as the bolts behind at the top under the wheel arch are a biatch
so should i attempt to tighten it up myself or take it back
i would rather do myself then driving all the way there and waiting for it etc
so what to use and how to
im sure you guys must know some tricks
wheel on or off
special tool??
PostPosted: Tue Oct 17, 2006 8:15 pm
For the rear bolts/nuts I use a Sidchrome 7/16" short ring/OE spanner, with the ring end severely thinned down on the grinder.
On the front bolts you can use a 3/8 square drive socket and ratchet. :wink:
Wheel off is better.
PostPosted: Tue Oct 17, 2006 8:27 pm
so its not un doable myself or is it very difficult
also i am assuming i close the door when tightening
PostPosted: Tue Oct 17, 2006 8:35 pm
Not hard at all, really.
Yes I'd close the door. :lol:
PostPosted: Tue Oct 17, 2006 8:37 pm
thanks very much i will try
fingers crossed
PostPosted: Tue Oct 17, 2006 10:05 pm
I took my hinges off a few months ago, all i used was a ring spanner from memory.
No fancy schmancy tools, was pretty straight forward.
Shard
PostPosted: Tue Oct 17, 2006 11:10 pm
just take the wheel off and stick your head right up there if you can and go for it :lol:
its not a real fun job
 Post subject: Flex
PostPosted: Fri Oct 20, 2006 7:11 pm
A short flexidrive works real good too... :idea:
Users browsing this forum: No registered users and 72 guests
