It is currently Fri Jul 18, 2025 9:43 am
PostPosted: Wed Oct 18, 2006 4:37 pm
Hello,
As you may or may not know I am about to rip out Lillee's heart and replace it with a slight faster heart with 1275 instead of 1152 ccc.
So all you NSW people, tell me what the deal is to register it and get insurance legal bla bla. I have no idea. What does a blue slip involve? can any garage do a blue slip inspection? What forms do I have to fill at the RTA, tell me step by step and how much it will cost.
Thanks!
Lillee - 1969 Morris Mini K
PostPosted: Wed Oct 18, 2006 4:41 pm
Are you guys allowed to have Webers on your cars?
Legally...
PostPosted: Wed Oct 18, 2006 5:03 pm
Depends what year the car was made :D
Jon
PostPosted: Wed Oct 18, 2006 5:06 pm
go to a place that can do blue slips (RTA will direct you if you dont know) then get the blue slip done cost me $20. take it all back to rta and they change number, im my case cause its turboed i have to get engineered
you will need some kind of recipt for engine
easy :)
PostPosted: Wed Oct 18, 2006 5:11 pm
I did mine whilst converting over to Concessional Rego Scheme (Club plates) so didn't need a blue slip but...
Yes willy - we can run webers, delllortos or SU's
Not all garages are licenced to do blue slips (mostly due to the extra cost they have to bear to be licensed and pre-purchase the books). The RTA used to have a link on their website and a helpline as to where to find blueslip garages.
Blue slip really isn't anything more than a pink slip with regard to testing or inspecting the vehicle EXCEPT that they verify the VIN or chassis number and engine number to ensure they aren't on the stolen or writeoff register and are suitable for the type of vehicle being presented - a 1275 A series engine on a mini (with disc brakes) will be OK but a rotary engine would require an engineers report to be presented for example. Some garages inspect suspension, brakes, seatbelts etc more rigourously on a blue slip than a pink one.
If your car is roadworthy, and you've done a REVS check on the engine (before you built it :shock: ) you should be OK.
For the insurer, I just rang them up and changed the details over the phone (have done this with both Shannons and NRMA Classic previously) with no problems.
KB
PostPosted: Wed Oct 18, 2006 5:21 pm
whe you are talking to the blue slip man tell him it is 1273cc.... over that u need an engineers report.
Elmo was 998 orignally, I put a 1293 in and the blue slipper asked my capacity i said 1275 and he says are yu sure its not 1273? i said oh yeah thats right..... :wink:
PostPosted: Wed Oct 18, 2006 5:35 pm
that problem is because the big RTA book has a typo, that lists Mini 1275 as 1273cc.
I pointed it out and showed my rego for Ha-ha, which says 1275... :wink:
Barney was registered as 998, and is now legal 1275, no problem.
They didn't even check it has discs, which it does. I had to point it out.
Go see Brad's mate.... :wink:
PostPosted: Wed Oct 18, 2006 5:44 pm
So what happens if its rego'd in NSW but the engine number doesn't match the rego?? Is it jsut a matter of swappiong it with a blue slip. That is if the capacity is the same and type as what t was manufacture for? aka 1275 replaced with another 1275?
Coz i was thinking of transplating my engine from my LS into the new mini.
:wink: :) :o
PostPosted: Wed Oct 18, 2006 5:46 pm
Yes just go to a blueslip place, it's a painless process, takes 5 mins.
They will just check the VIN or body number of the car and the engine number. :wink:
You will need to prove it's yours, either receipt, old rego papers, etc.
PostPosted: Wed Oct 18, 2006 7:00 pm
When you change a motor in NSW you need to show a receipt for the new motor. :wink:
PostPosted: Wed Oct 18, 2006 7:03 pm
Added to what everyone else has already said
Make sure you tell the blue slip inspector that the mini with the big bore motor has disc brakes and that he notates that. Most of them do not know that a big bore must have disc brakes.
The reason is that it will pop up on the RTA computer and you will have to trot back to the Blue slip inspector's for him to bend down and say yes it has disc brakes anmd notate that on the blue slip.
PostPosted: Wed Oct 18, 2006 7:05 pm
Ask for a blue slip adjustment, thats what it is and as the doc said its quick and painless.
Steve
PostPosted: Wed Oct 18, 2006 7:09 pm
OK so I need a reciept for my engine, hmm graham can give me that i think... $100 should cover it as that is what I got it for :wink:
thanks for all the info. Can you tell me how much it costs to do a blue slip? it's not like $500 is it??? :?
PostPosted: Wed Oct 18, 2006 7:18 pm
does gr do them, my mecha's appreintice stole cds out of my car so........
PostPosted: Wed Oct 18, 2006 7:24 pm
about $49 to $60.
You just need a receipt for the block, not the rebuild.... :lol:
or if it IS yours, from another of your cars and has been in the shed for a zillion years (like my S motor) write them a letter explaining this. That's all I needed 12 years ago. :wink:
<edit> 1360LS, PM sent. 8)
