It is currently Sat Jul 19, 2025 11:24 am
 Post subject: Front hub bearing seals
PostPosted: Fri Nov 05, 2004 9:22 am
My book(s) say to fit the bearing seals "with the lip facing towards the bearing"
:roll: Real helpfull that is.....
Looking at the seal, there is a groove on one side, with a spring type retaining ring in it. Does this side face the bearing? That is my interpretation of the above quote from the book.
PostPosted: Fri Nov 05, 2004 9:35 am
Yes
PostPosted: Fri Nov 05, 2004 9:39 am
:D sweet! thanks Jimbo.
PostPosted: Fri Nov 05, 2004 9:45 am
Yes. Make sure you lubricate the seal running surface with a bit of oil or gresse so the seal does not get damaged.
Chris
Everything I like is either
PostPosted: Fri Nov 05, 2004 10:18 am
Cool, thanks. Will do!
PostPosted: Fri Nov 05, 2004 11:21 am
just did my bearings yesterday, yes spring towards the inside, car rolls nice and quite now :D
1974 Moke - 998cc
PostPosted: Fri Nov 05, 2004 11:35 am
Fill it up grease before you do that :wink:
PostPosted: Fri Nov 05, 2004 11:54 am
Love the sound it makes when you have just packed the Hub full of grease. You push it on, take it off... :roll: :oops:
PostPosted: Sun Nov 07, 2004 8:37 am
LMFAO. Yeah, fill the seal with grease as well. Obviously only pack your wheel bearings as required, but if there's any other room, I reckon fill it with grease. Less space for crud to get in then.
