It is currently Sat Jul 19, 2025 9:25 am
PostPosted: Sat Nov 06, 2004 9:23 pm
Guys.... considering going full aftermarket suspension upgrade to one of the above brands. Any ideas on 1. which setup to go, 2. Approx Cost, and 3. Whether it is a complicated job or not......
Steve
I got nuthin......................
PostPosted: Sun Nov 07, 2004 8:35 am
well i run spax front adjustable shocks and rear koni adjustables, with a rear swaybar. It does have great turn in but rear end can snap around if your to slow. The koni's and gaz are a better built shock then the spax.
For new shocks you wouldnt be looking at much change from $800 for the konis and gaz, maybe $600 for the spax.
I got mine from UK ebay, payed $100aus shipped for the spax and $150aus shipped for the konis :D
Then there is coil overs, wouldnt recomend these for a street car, race only.
Easy to fit, fronts just bolt in, rears need tanks taken out to fit.
1974 Moke - 998cc
PostPosted: Sun Nov 07, 2004 9:16 am
Cheers for that 13sec...... i just wanted to find out if anyone was running and their thoughts..... seems that there isn't many out there!!!!!!!
PostPosted: Sun Nov 07, 2004 10:57 am
sg, you are running hydro suspension at the moment right?? if so, it's a little bit more complicated, you need to get the shock mounting brackets for the front (either from a wreckers or shop) and then you can put the shocks in.......i'm not sure about the back because they just mount to the inner arch.......
play 3d car games for free
PostPosted: Sun Nov 07, 2004 1:21 pm
Cool thommo.... will chase those parts up. Thanks again for the info.
PostPosted: Sun Nov 07, 2004 1:35 pm
Thommo, If you need fron mouts, i've got a few in a box here.....
Drop me an email [email protected]
J
PostPosted: Sun Nov 07, 2004 5:46 pm
i got my gaz cheap :D cant remember how much but i think it was about $320?
lookin for another clubby
 Post subject: suspension
PostPosted: Sun Nov 07, 2004 6:39 pm
Steve,
You already have shocks mounted to the front. They are brand new original types. The front and rear have negative camber setups as well. If you want to upgrade you can change the front to whatever performance type you wish, however changing the rear helper springs to shocks is not a good idea. If you want to make some improvements a rear swaybar is a good option, give that a go and I think you will find your rear pitch will reduce. G.
1962 Mini Speed sports sedan
PostPosted: Sun Nov 07, 2004 6:48 pm
Before you lash out on a rear bar for a hydro, I would fit comp rear hydro bumpstops. $72/pr approx at Karcraft. p/no C-AJJ3313. Works for me... 8)
They have a similar effect to a rear bar on corners by progressively increasing spring rate, but they also reduce fore & aft pitching and give you better turn in. :wink:
PostPosted: Sun Nov 07, 2004 11:17 pm
J
nah i right thanx Jim.....dry suspension on teh clubby :)
Users browsing this forum: No registered users and 70 guests
