It is currently Mon Jul 28, 2025 8:10 pm
 Post subject: Oil pressure guage
PostPosted: Fri Nov 03, 2006 12:26 pm
The moke came with a busted capillary type vdo oil pressure guage. I need t replace it. I can get the VDO one again or have people have used others more sucessfully.
or
Has anybody successfully installed an electric sender?
Thanks
PostPosted: Fri Nov 03, 2006 12:28 pm
ausmini mod
ausmini mod
So do the mini's and mokes run Electric oil pressure guages or Mechanical as standard?
I thought you could buy both now (I know you can in AutoMeter and SpecoMeter, would assume the same for VDO)
Peter.
PostPosted: Fri Nov 03, 2006 12:31 pm
Peter.
The moke had none, this is an aftermarket one plumbed into the bolt hole below the oil line to the block.
PostPosted: Fri Nov 03, 2006 12:48 pm
I have a VDO capillary gauge with stainless braided line. Its super accurate. The only thing i hate is that its reading in Kilopascals and not PSI
PostPosted: Fri Nov 03, 2006 12:57 pm
ausmini mod
ausmini mod
Is capillary type = Mechanical?
PostPosted: Fri Nov 03, 2006 2:16 pm
Yes, Pristic.
Jonathan
PostPosted: Fri Nov 03, 2006 2:27 pm
Yep - it uses a capilary line that delivers oil all the way to the gauge rather than an electrical type which uses a sender that is connected to the gauge via electrical wire only.
PostPosted: Fri Nov 03, 2006 2:31 pm
one of my cars had an electric VDO on it, it worked in that it told me the oil pressure as well as the capilliary one, but I prefer the look of the smiths ones...
I found it the other day when I was cleaning up. It's a can the size of an indicator flasher unit that goes in the capillary hole in the block, and the guage itself is the same size as the standard one
PostPosted: Fri Nov 03, 2006 2:43 pm
ausmini mod
ausmini mod
Thanks guys,
Hey Bloke, while researching, I found this...
http://www.grandprix.net/upgrades/oilgauge.html
Not sure if it helps you or not though.
I guess from the posts above people have had both Elec and Mechanical working fine in their minis.
Peter.
PostPosted: Fri Nov 03, 2006 3:19 pm
pristic wrote:
Thanks guys,
Peter.
Thansk for all the feedback. I post up what up what I do when Im finshed, :)
