It is currently Mon Aug 18, 2025 10:07 pm
PostPosted: Fri Nov 03, 2006 9:04 pm
I cooked my coil on my clubman tonighta nd wnated to know what coils you guys recommend buying new?
Cheers Ian
Ian - My Ve SSV Ute - Looking for a Mini
PostPosted: Fri Nov 03, 2006 9:09 pm
U cooked ur coil? Have u found the cause of this failure? Seems u have pulled to much current through it then? Did the coil need to have a ballast resistor in cct? Did u fit a ballast resistor to it?
PostPosted: Fri Nov 03, 2006 9:23 pm
I tried to wire up a tacho, i have removed the wire so it wont do it again :P
PostPosted: Fri Nov 03, 2006 9:35 pm
Was connected to the neg side of the coil? Is it an aftermarket tacho? Did u use the green wire?
PostPosted: Fri Nov 03, 2006 9:38 pm
Connect to -ve and it's a 3 gauge cluster from a clubman s...
PostPosted: Fri Nov 03, 2006 10:26 pm
did you cook your tacho?
PostPosted: Fri Nov 03, 2006 11:14 pm
DOn't think so/ Hope Not
PostPosted: Sat Nov 04, 2006 7:22 am
bosch 8)
PostPosted: Mon Nov 06, 2006 6:37 pm
Bosch GT40 for me!
1975 Mini SS converted to a Mini Miami
1978 Clubman S
1965 Mk1 Cooper S
2005 BMW 318i (Well at least its a real BMW)
"Dont take life to seriously, you may never get out!"
PostPosted: Mon Nov 06, 2006 6:57 pm
GT40 is what i run on both cars.
Does anyone know if the bling gold Lucas ones are any good? or worth the money?
Users browsing this forum: drmini in aust and 130 guests
