It is currently Sat Aug 02, 2025 3:15 pm
 Post subject: exhaust legality qu
PostPosted: Sat Nov 04, 2006 12:32 pm
Are you alowed to have a custom exhaust on a mini with the exhaust pipes exiting in front of the rear wheel?
PostPosted: Sat Nov 04, 2006 12:39 pm
High heel ninja
In a word no, any side exiting exhaust ads a risk of carbon monoxide getting into the passenger compartment & causing the driver to black out.
Doogie
PostPosted: Sat Nov 04, 2006 12:45 pm
my bedford had that, the only thing that my mecha said that i had to have it protruding the skirt of the car but not protruding the widest part of the car, car did come from melb though
PostPosted: Sat Nov 04, 2006 12:58 pm
on a mini van its ok
it has to be a certain distance from the last door or rear passenger door
57 Morris minor
88 Rover Mini
PostPosted: Sat Nov 04, 2006 1:01 pm
Would be acceptable only if the rear windows were made non-opening.
Also exhaust has to be angled (see the National Code of Practice)
PostPosted: Sat Nov 04, 2006 5:56 pm
Last I knew , in NSW it had to be 450mm behind the last opening window or door , I've wonderred before about putting lakes pipes from each side of some LCB's on a van (I know , mostly wank value but I think it'd look good ) but haven't tried it . The only thing is the outlet would bein front of the rear opening doors but I can't see that being a problem as the exhaust is normally either just behind or just in front of the doors anyway , nowhere near the 450mm required for a side exhaust . The biggest problem would be the reduced ground clearance from the pipes going under the side rather than all the way to the rear . Speedbumps (or Judder Bars for our NZ contingent) could be a problem ....
PostPosted: Sat Nov 04, 2006 6:29 pm
Thankyou. That will be my christmas present to me. Van will be blue by then, hopefully with webasto sunroof.
Just a quick tidy up for the daily :D
PostPosted: Sat Nov 04, 2006 6:38 pm
Just check it with an engineer first , especially with a sunroof as they may class it as a windoe and the exhaust will have to be the required distance behind it's rearmost opening edge .
