It is currently Wed Aug 06, 2025 11:35 pm
 Post subject: rubber boot seal
PostPosted: Sun Nov 05, 2006 4:19 am
hi all
I got this rubber boot seal from clark rubber the other day. I put I fitted it to the body of the car tonight and now the boot wont shut.Image
Has anyone else used this stuff with any luck.
Thanks guys and gals
blokeinamoke wrote:
 Post subject: boot seal
PostPosted: Sun Nov 05, 2006 8:11 am
Hi i bought a seal from there to, but i bought the smaller one it works a treat.
:lol: :lol:
Steve
PostPosted: Sun Nov 05, 2006 10:48 am
Is not the right seal, AFAIK all Aus mini's had seal that attached to boot lid, either with special clips or glued to boot lid......
This type of seal could work if fitted to boot surround lip on body, but sounds as if the seal you have is too big.
Did Clark rubber sell you this a s a boot seal for a Mini ?
I beleive their part number is 225.018 ?
Sir Alec! we are not worthy!
 Post subject: BOOT SEAL
PostPosted: Sun Nov 05, 2006 5:27 pm
nah its from clark rubher. I will blast down there and try to find a smaller one. It looks perfect in theory but the thing wont close.steve Is there any chance that you could take me a photo of the one you have ? It would be greatly appreciated.
blokeinamoke wrote:
 Post subject: Seal
PostPosted: Sun Nov 05, 2006 5:51 pm
The seal i bought is the same as yours but only smaller, they only had to sizes when i bought mine here is some pics.
Steve
PostPosted: Sun Nov 05, 2006 7:10 pm
i bought the repco one, its not a complete seal but about a teaspoon of watergets in on a nights heavy rain,
PostPosted: Sun Nov 05, 2006 7:38 pm
It is very important to have a good seal on the boot. Because the exhaust pipe is so close to the bottom of the boot lid it can suck exhaust fumes into the car. (been there done that, got the headache :lol: )
PostPosted: Sun Nov 05, 2006 10:07 pm
thanks a lot mate.
blokeinamoke wrote:
 Post subject: Re: Seal
PostPosted: Mon Nov 06, 2006 12:32 pm
Steve
hmmmm - like the look of that! Does it seal well???
PostPosted: Mon Nov 06, 2006 3:18 pm
it doesn't leak at all not even a drop.
Steve
PostPosted: Mon Nov 06, 2006 7:04 pm
ive got a seal on my actual bootlid, and nothing on the actual boot....it leaks when it rains hard and when i wash my car :( would it work if i get that small inner seal and keep the old seal on the bootlid or would the boot not close????
>Rude<
1992 Toyota Starlet GT EP82
PostPosted: Mon Nov 06, 2006 7:26 pm
My original one still seals. The on-the-bootlid style one.
 Post subject: Boot Seal
PostPosted: Mon Nov 06, 2006 7:45 pm
I think if you had both the boot lid would not close.
Steve
PostPosted: Mon Nov 06, 2006 8:51 pm
Clark make several similar seals. I've just bought some to seal the rear of my Traveller..seems to work fine. The kind I bought would have to be glued onto the boot lid. Its a double tube affair with a flat edge that I glued to teh body. With pressure it collapses into a flat section about 2mm thick.
Cheers, Ian
PostPosted: Tue Nov 07, 2006 9:00 pm
Steve
Yep i installed exactly the same seal as steves. It works fantastic. I has never let in any water not that we have to worry about that kind of thing these days. Rain wat is that again!!
71 Clubie, 1310A+, 45 Weber, Kent286md cam, Brownrigg extractors
