It is currently Sat Aug 16, 2025 8:44 am
 Post subject: cooling set up.
PostPosted: Mon Nov 06, 2006 5:27 pm
Hi all
Could ya's have a geez at my options and tell me what the best set up for a hot 1100 would be. I have got a high flow water pump I just have to sort out the fannage.
Stock fan with a reco radiator(tanks removed and cleaned) Retro fitted thermo fan with stock radiator, retro fit front mount with thermo fan or 3 core with either of the above mentioned fan set ups.
Thank you all
blokeinamoke wrote:
PostPosted: Mon Nov 06, 2006 5:33 pm
ausmini mod
ausmini mod
I would stick with the plastic 11 blade fan and clean the radiator. Its designed to draw air around the engine and out past the wheel.
Did the High flow water pump fit or the block had to be modified?
Peter.
PostPosted: Mon Nov 06, 2006 10:10 pm
it bolted straight up mate
blokeinamoke wrote:
PostPosted: Tue Nov 07, 2006 8:24 am
Is it a roundy or a clubby?
I put an Alfa Romeo front-mount radiator in my LS, with its own thermo fan. That sure fixed the heating troubles.
Bewdiful :wink:
PostPosted: Tue Nov 07, 2006 8:36 am
See if you can find a Morris 1100 radiator, they have a larger capacity, are about 2" wider than a Mini one and can quite easily be made to fit in the same position. Use the standard 11 blade plastic fan.
Curly
PostPosted: Tue Nov 07, 2006 9:12 am
Bewdiful :wink:
Got any pics?
PostPosted: Tue Nov 07, 2006 9:19 am
If your regular radiator and fan is not keeping your mini cool all the time then you need to look at why it is doing so rather than going to a bigger setup straight away... Too cool is not always the answer
With a brand new mini 3 core radiator, any fan, the correct cap, the correct timing, a working thermostat and a good coolant flush all minis should run cool and never overheat...
Example: I took my old 3 core out of my car and compared it to a reconditioned 3 core and my old ones was comparatively heavier as it was chocked full of rust and gunk from years of service. The reconditioned one went in and I straight away noticed a big drop in temperature, even when idling in traffic.
Just my 2 cents
PostPosted: Tue Nov 07, 2006 9:49 am
arpy69 wrote:
Got any pics?
Unfortunately not. See if Santo (leyland brother) has any. He now owns the car. :wink:
PostPosted: Tue Nov 07, 2006 10:42 am
Mini-dunger I find your atvar totally abhorrent and inappropriate
David L
Users browsing this forum: Bing [Bot] and 337 guests
