It is currently Mon Aug 11, 2025 8:13 am
 Post subject: cam
PostPosted: Tue Nov 07, 2006 3:24 pm
hey what does a slot drive cam mean? i have a 1275 from a 1100s what type cam would i be looking for
PostPosted: Tue Nov 07, 2006 3:49 pm
That would depend on what sort of oil pump you have....
PostPosted: Tue Nov 07, 2006 3:52 pm
It would have come with a spider drive cam from the factory.
I believe there were three main types of 'driving' the oil pump, that is, how the end of the cam shaft connects to the oil pump.
Pin drive, with a pin in the end of the cam, and a slot in the oil pump drive to fit over it, early morris and cooper s type.
Spider drive, as fitted to 1100s 1275 motors and later mini motors (i think?) Has a small 'gear' on the oil pump, with a small piece called the spider which sits on this and fits into the end of the camshaft. Bad news if dropped into the gearbox!
Slot drive, with a slot in the end of the cam, more modern A series engines, UK from mid 70's (I think)
Matt
PostPosted: Tue Nov 07, 2006 6:25 pm
Right now the `spiders' as used on 1100S are NLA (no longer available) so if you have one don't lose it.
You can put a slot drive cam into any A series, you just need to get a `slot drive' oil pump to go with it. :wink:
PostPosted: Tue Nov 07, 2006 6:57 pm
thanks for all the info!!!! well appreciated :wink:
Users browsing this forum: No registered users and 119 guests
