It is currently Sat Aug 02, 2025 12:27 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Wed Nov 08, 2006 6:31 pm
On some minis you will find that the neck on the tank is not flat and no matter what you do you will not get a cap to seal.
You can fix it by building up the surface with solder and filing it flat.
I hear you......but I have used a stone on the lip of no less that 2 fuel tanks, to knock off any high spots or identify any low spost. Both were very flat, yet still leaked.
This is a pic if the sealing face on a tank I got in a job lot recently. It has a raised lip on the face, which is different to any other I have seen. This looks like it will seal much better, but what is this from?
