It is currently Sat Jul 19, 2025 10:48 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Nov 08, 2004 5:08 pm
have you got a pic of these wheels to let everyone else see them?? you could always sell of your wheels you have now and get a newer set that fit over the brakes. wouldnt lose out to much.
1974 Moke - 998cc
PostPosted: Mon Nov 08, 2004 7:42 pm
I do have a cupla shots of the wheels, but I took them with my phone. And I dont know how to post them on here???? Anyone able to give us a pointer!!! The quality of the shots is still ok though. As for sellin the wheels, I honestly couldnt be stuffed. Paid $1200 for wheels and Yokohama A539 165's, I doubt I would get a great deal for them, even though they are in as good as new condition!!!
Like I said if I go ahead with it all, will just do it as if I have 10in wheels, though it kinda defeats the purpose dosnt it??
Email to me and I will host them. 8)
PostPosted: Mon Nov 08, 2004 7:59 pm
Will do doc, when I get to a pc where I stored all the photos, should get a chance 2morrow. Thanks..... By the way 13secmini, I sused out your web page, MAN what a mission that job looks like. Good onya!!!!
PostPosted: Mon Nov 08, 2004 8:03 pm
Insert dimplomatic reponse about being sorry for your trials and tribs and what not...
You could easy sell the brakes as a kit man. Sell em to someone in NZ or UK. Not covered under corresponding laws. So if the sh!t fails no one's coming looking.
PostPosted: Mon Nov 08, 2004 8:13 pm
Its not worth the effort man, nothing on this car has ever been easy and never will be. Depends on how enthusiastic I get about it now. As to if I will go through with the conversion.
PostPosted: Mon Nov 08, 2004 8:25 pm
Hanra wrote:
Well I was surprised to, cause the rotor is only 12mm thick, but thats what Repco have told me. They contacted DBA while I was there to place the order, so I guess Ill have to wait and see, its going to take 2 weeks for them to get here so Im assuming that DBA have to make them especially, I tried to get blanks that havnt had the stud pattern drilled but was told they wouldnt supply them like that??
You can get blanks.....but they are special order only. When i called DBA for Ben they told me that the wait for blanks would be between 6 months and a year :roll:
Also dont think those rotors will be vented....im pretty sure they are solid only.
[Maverick] 1971 Mini K
PostPosted: Tue Nov 09, 2004 8:33 am
DBA had already had a production run so they said it would be an 18mth wait till they did another run, so then I would be able to get a blank rotor.
PostPosted: Tue Nov 09, 2004 9:47 pm
OK, here's Hanra's wheel pics.
BTW, I looked at Mini Mad's ones tonite and they do look bigger inside than these...
PostPosted: Wed Nov 10, 2004 8:34 am
Thanks for that Kevin, Im sure every 1 should get the idea that they just dont fit!!!!!
PostPosted: Wed Nov 10, 2004 9:07 am
those rims look damn strong though!
PostPosted: Wed Nov 10, 2004 9:16 am
did you see the rims with no tyres? looks like they would have the same profile under the rubber (i doubt they're any thicker (ie stronger)
whats does the outside look like, almost like they would be 10" centers with massive rim
Expert in training
PostPosted: Wed Nov 10, 2004 9:19 am
I had this problem with my superlights, i spaced them out & fit new flares now im fixing a wheel rubbing problem.
Just cut them down as if you were fitting them to 10"
65 DELUXE
69 DELUXE
MY MINI PICS: http://www.flickr.com/photos/morrie850/
PostPosted: Wed Nov 10, 2004 12:53 pm
Once the tyre is off, the rim profile matches what u see on the outside. They arent any thicker. Yeah, they are pretty much a 10in centre with a 12in outside diam. I would have to space the wheel out no less than 30mm which is just to far out. Not worth the hassle, so I might continue on with it next year and get the rotors machined down. Had enough stuffin around this year!!!!!
If any1 has a photo of the inside of there 12in rim could they post it up here, just so I can see what other rims look like.
PostPosted: Wed Nov 10, 2004 4:42 pm
Ping `Mini Mad' and ask if he can take a pic, to show the difference...
When we bolted his 12x5 Superlites up with NO spacers there was still a couple of mm caliper clearance, with full size Honda discs!
He has had these wheels for a couple of years.... :wink:
Users browsing this forum: awdmoke and 106 guests
