It is currently Mon Jul 28, 2025 9:02 pm
 Post subject: Can't get it out !!
PostPosted: Tue Nov 14, 2006 2:22 pm
I want to replace the bushes in the steady bar (near the brake and clutch cylinders) the engine is out so I've got easy access - there is no nut on the bottom of the bolt/stud the whole thing is just rotating in the bush and won't move vertically. I've tried the ball joint spitter, a G clamp and the BFH but no move :evil:
Any one got any ideas to get it out ?
David L
PostPosted: Tue Nov 14, 2006 2:27 pm
clamp the bottom of the bolt and grab a small grinder with a cutting disk and cut it off
PostPosted: Tue Nov 14, 2006 2:28 pm
Can you get a screwdriver or some sort of lever under the hear of the bolt to get it moving up whilst, if poss, whacking the end of the bolt (with the nut screwed on flush) to knock it up.
PostPosted: Tue Nov 14, 2006 2:33 pm
it may not be a bolt...
i've forgotten the name of it...
but it looks like this..
it's got a silly name... like a bogan, mongoloid or some offensive term that feralsprint would get all silly over.... :D
PostPosted: Tue Nov 14, 2006 2:41 pm
AHH so that top lip could be catching under the bracket - need to wiggle a bit :wink:
David L
PostPosted: Tue Nov 14, 2006 4:11 pm
The one I had that looked like that, was not able to be removed without a hacksaw, or removing the brackets on either side. The centre metal bit was way too large to go through the holes.
Use a hacksaw! :wink:
matt
PostPosted: Tue Nov 14, 2006 4:22 pm
or do what i did...
bend the bracket down a bit and try get it out on an angle
try not to snap the bracket..
..like i did.... :oops:
PostPosted: Tue Nov 14, 2006 4:38 pm
edit
David L
I'm about to take the master cylinders out to O/haul them so no dramas then - the brackets will come out then
David L
PostPosted: Tue Nov 14, 2006 4:46 pm
if you're taking the masters out, you can just take the baseplate out... easy schmeezy..
Users browsing this forum: No registered users and 67 guests
