It is currently Fri Aug 15, 2025 6:06 am
PostPosted: Sat Nov 18, 2006 12:25 pm
hey guys
im in a catch 22, i was putting my new LCB exscractors on the engine and its such a tight fit, so i stupidly undid one of the engine mounts to make it easier and the exsorst is on fine but now cant fit the engine mounts, :x
stupid question but has anyone drilled a new hole for the engine mounts,
when i take my engine out next time i am going to grease them, and make a guide out of steel and weld it to the subframe so it just slide in,
PostPosted: Sat Nov 18, 2006 3:56 pm
no, and don't do it! just work on the exhaust.... undo ubolts and things and wiggle it around.... can be a real pain in the bum
PostPosted: Sat Nov 18, 2006 4:38 pm
yeah i didnt think it would be good,
PostPosted: Sun Nov 19, 2006 12:39 am
Undo the engine steadies and you have enough of a leeway to moove the engine around wthout having to undo the mounts. Removing the manifold studs in the engine head will also allow you to slide the LCB flange into place rather than having to go over the studs.
PostPosted: Sun Nov 19, 2006 6:28 pm
yeah engine steadies are off, but she is inches from me sliding a screw driver in the hole to pivot the thing closer,
is it posible to leave the engine mounts on the subframe and slide the engine onto the engine mounts,
Users browsing this forum: Bing [Bot] and 296 guests
