It is currently Fri Aug 01, 2025 6:17 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3  Next
 Post subject: HELP!! putting engine in
PostPosted: Sat Nov 18, 2006 6:46 pm
Die Die Die!!
ok so i get to the point where im putting back in my engine and i just cannotget the drive shafts to go in.... which is makig it just as hard to get the engine mounts to line up... any got any tips? or could lend a hand next weekend or sometime during the week to get them in ?
PostPosted: Sat Nov 18, 2006 6:48 pm
How are you doing it , have you pulled the inner cv's apart or "popped" them off the diff ? willy , is there any difference between aussie clubbie pot joint's and rover pot joints , I don't think there is but anything's worth a shot ???
PostPosted: Sat Nov 18, 2006 6:54 pm
Die Die Die!!
i did but they are propperly on now...
PostPosted: Sat Nov 18, 2006 6:58 pm
so there done?
some metro, so i assume late mini ones also are a different size, we struggled with a mates a+ for ages before realising the pots are slightly smaller :evil:
PostPosted: Sat Nov 18, 2006 7:10 pm
they should put a thread under the how to's section for all the different type of joints and what not, include tips :wink:
PostPosted: Sat Nov 18, 2006 7:25 pm
Die Die Die!!
jbeenz wrote:
so there done?
i switched them already for the ones in my A series...
PostPosted: Sat Nov 18, 2006 7:47 pm
good good :D
on the how too issue : rubber x's step 1: aquire mechanicly minded hampster....
PostPosted: Sat Nov 18, 2006 7:49 pm
jbeenz wrote:
good good :D
With multi jointed fingers .....
PostPosted: Sat Nov 18, 2006 8:01 pm
:lol:
PostPosted: Sat Nov 18, 2006 8:34 pm
Die Die Die!!
sports850 wrote:
jbeenz wrote:
good good :D
great help guys :roll: :lol:
PostPosted: Sat Nov 18, 2006 8:37 pm
What do you expect on a Saturday night ....
PostPosted: Sat Nov 18, 2006 9:32 pm
you need two guys
one to move the driveshaft, and one to move the engine around,
do one shaft at a time, i think the long one first.
failing that, you need to undo your front suspension on one side or both sides
PostPosted: Sun Nov 19, 2006 12:34 am
Jack the car up so that front wheels are just off the ground , you can then move the joints into position by turning either front wheel ........cheers
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Sun Nov 19, 2006 1:49 am
Die Die Die!!
Spaceboy wrote:
you need two guys
i did have a mate... couldnt even get the long side in... or the engine mounts to line up... if i could have gotten the engine mounts to line up i would have taken both sides off and put them in seperatly...
Die Die Die!!
cars on jack stands... still no luck...
Users browsing this forum: Bing [Bot] and 124 guests
