It is currently Sat Aug 02, 2025 11:02 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Nov 19, 2006 1:55 am
_666_ wrote:
Spaceboy wrote:
you need two guys
one to move the driveshaft, and one to move the engine around,
do one shaft at a time, i think the long one first.
failing that, you need to undo your front suspension on one side or both sides
i did have a mate... couldnt even get the long side in... or the engine mounts to line up... if i could have gotten the engine mounts to line up i would have taken both sides off and put them in seperatly...
you should be able to get at least one side in
my advice is to take the car off the jacks, and put it on blocks of hardwood or something to bring the car level
if you still cant get the engine mounts to line up
loosen the bracket on the bottom of the engine that secure the engine mounts, remember to tighten back up.
use a screwdriver through the hole in the subframe to make small adjustments
PostPosted: Sun Nov 19, 2006 1:57 am
Die Die Die!!
how would i get under the car to work on it if its on blocks of hardwood ?..
i half got one side in.. but i assume it wasnt propper as it came out agian
PostPosted: Sun Nov 19, 2006 2:05 am
try it from above for the driveshafts, did you remove your bonnet?, once you have one pot joint in, pull the engine towards and into that giving just enough room so then the other guy can fandangles the other driveshaft in
otherwise pop your suspension
get the driveshafts in first, then line up the engine mounts
PostPosted: Sun Nov 19, 2006 2:08 am
Die Die Die!!
yeah i removed my bonnet... and i virtually got one in.. buti need a long pole so i can lever the engine i needed bout minimum 2" clearance to fit the other side... only way i could have seen it working is if i could have put them both in at the same time and then lowered the engine and use that force to pop them in.. but then i have trouble keeping the balls in..
PostPosted: Sun Nov 19, 2006 2:16 am
get the car level first cos you shouldnt need a pole.
we put the 1132 in the banger just recently, we tried one side and couldnt get enough clearance, tried the other side and just managed it in..
pack your balls with grease
PostPosted: Sun Nov 19, 2006 6:27 am
Have you split the top ball joints and the steering tie rod ends so the hubs hang outwards or did you just pull the engine out with the hubs still attached ?
PostPosted: Sun Nov 19, 2006 11:09 am
Die Die Die!!
i cracked the top ball joints but not the tie rod ends...
and ill try getting it level ryan.. i have to borrow an engine lifter again now :S
PostPosted: Sun Nov 19, 2006 11:47 am
NAV-MAN
How much grease do you have in the pots? Too much and you can't get the drive shafts in. I found out the hard way :oops: I delegated the greasing part to a friend and my words were put some grease in the pots for me, little did i know that he'd filled them! :shock:
PostPosted: Sun Nov 19, 2006 12:54 pm
Hey
NEVER EVER _ NEVER EVER put a car on bricks, pavers or besser blocks - they will crack under the weight and the car will collapse down.
If your under a mini with an engine in it and it falls down, you will not survive it
A neigbour of mine was killed back in March being under a poorly supported car. The electricity meter reader found him dead fifteen minutes after my neighbours had wife driven off to the local shop to get lunch for them both.
ONLY EVER USE PROPERLY BUILT AND PROPERLY LOCATED JACK STANDS
If you can't then dont do the job !![/b]
PostPosted: Sun Nov 19, 2006 1:00 pm
Die Die Die!!
Mike_Byron wrote:
Hey
well i guess i could jack rear end up as opposed to lowering the front end...
PostPosted: Sun Nov 19, 2006 1:04 pm
Die Die Die!!
not alot of grease actually... one sides nice.. (the side i could even get close to getting in..) and the side i was trying to get in wasnt all that greasy... i was concerned there wasnt enough... but i just wanted to get the car together at that stage...
PostPosted: Sun Nov 19, 2006 6:21 pm
_666_ wrote:
Mike_Byron wrote:
Hey
just go and buy jack stands, there nothing at super cheap,
PostPosted: Sun Nov 19, 2006 9:13 pm
Die Die Die!!
buztoy wrote:
_666_ wrote:
Mike_Byron wrote:
Hey
read the whole thread befpore makign a comment in future... i already HAVE jack stands
PostPosted: Mon Nov 20, 2006 5:42 pm
sorry gov, didnt want a to see a article in the paper, about ausmini user killed by mini, my boss had a 12 ft tinny fall on him while he was adjusting the rollers on a guys trailer, cracked ribs though,
PostPosted: Mon Nov 20, 2006 6:58 pm
I will make an apology as well.
Having seen a number of my aquaitnances die over my 59 years, I regard any loss of life not due to natural causes as a waste.
I have had three people, with who I knew, die under a fallen car.
I never meant to imply that anyone was doing unsafe practices and it=f that was felt than I am sorry but I am not about promoting safe working habits. Its a very short life and a loooooong time dead.
