It is currently Sat Jul 19, 2025 12:52 am
 Post subject: Dash Clock
PostPosted: Tue Nov 09, 2004 1:09 pm
Hi guys! I picked up a dash cluster from P'n'P yesterday. It has a clock in the place of a tacho. The clock works, but needs calibration. It thinks it takes 40 seconds to complete 1 minute. How do I calibrate this thing?
Also, I picked up a standard mini tacho that i found lying around. Will it be easy for me to get this running without the PCB? I ve only got the PCB that is for the 3 gauge with CLOCK (not the 3 gauge with TACHO).
 Post subject: Here's a pic of it
PostPosted: Tue Nov 09, 2004 1:40 pm
PostPosted: Tue Nov 09, 2004 2:16 pm
heh...I know the one you got that from. I had my eye on it! I also wanted to have a 4 clock dash :wink:
Hey, what does the speedo go up to? 160 km/h ?
 Post subject: speedo
PostPosted: Tue Nov 09, 2004 4:39 pm
yep...only up to 160km/h
any ideas on the calibration of the clock??
PostPosted: Tue Nov 09, 2004 4:51 pm
1. smear abit of glue at the centre maybe thatll slow it down
2. are you afraid to pop it out
3. on pocket watches theres an adjuster on the back, what kind of power does the clock run on
hows the van comin along ray, anypics
Inconspicuously Conspicuous
PostPosted: Tue Nov 09, 2004 10:07 pm
Does not look like you have the glass for these guys :?:
PostPosted: Wed Nov 10, 2004 9:00 am
Duc:
i have popped it out, but havent had a look at any "adjusters"
van is going well...im building fromthe bottom up...i've almost got the subframes sorted out, the engine is ready to be put into the subframe, then i gotta work on the body to sit it on top.
The front floor is finally in!! (i learnt how to weld).
you can check out SOME stuff at www.freewebs.com/monrel
Gafmo:
i've already got a two clock dash (two glass pieces), and i got two more with the one i picked up from Pik'n'pay. That make 4 pieces of glass!!!
Only thing is that the clock needs a hole in the glass, but that's ok, my uncle is a glazier and can get one of his buddies to drill it or whatever they do to put holes in glass.
PostPosted: Wed Nov 10, 2004 9:06 am
not sure how the clock is powered. it shares a grounding point with the rest of the stuff on the PCB, but the power wire is seperate from the PCB, it has a male spade terminal screwed on the back of the clock. not sure which wire goes to this, and how many volts.
but as i said, i've thrown all kinds of volts at it, and it keeps the same calibration. i guess that is a good thing, since their is a lot of fluctuation in the voltage source in the car.
PostPosted: Wed Nov 10, 2004 11:49 am
1 mile to the 1.6 kilometres
40seconds to the one minute
just another calculation you might have to get used to... hehe
PostPosted: Wed Nov 10, 2004 12:07 pm
:lol:
 Post subject: Re: Dash Clock
PostPosted: Wed Nov 10, 2004 12:24 pm
I had a clubby tacho in my car for a short while, and didnt have the PCB for it, so, yup it can be done. I think there are 3 wires? one to the coil, one to positive, and a ground I guess? its been so long! :) then you need some power for the bulb.
'68 Morris Mini Matic (GF's)- complete!
'68 Morris Mini Deluxe - deciding on specs..
'63 Morris 850 - On the Shelf
Other various mini parts cars :)
PostPosted: Wed Nov 10, 2004 1:13 pm
The one to the Coil is connected to the Negative Pole 8)
 Post subject: tacho
PostPosted: Wed Nov 10, 2004 3:37 pm
thanks guys!
so for the tacho:
one wire goes to negatice post on the coil
one wire goes to the positive terminal of the battery?
one wire goes to ground
is that right??
PostPosted: Wed Nov 10, 2004 3:47 pm
One does not need to go to the battery but a continuse live feed..Say yourfuse box would be better
PostPosted: Wed Nov 10, 2004 6:12 pm
depends on the tacho
see post
http://ausmini.tziworld.com/viewtopic.php?t=2051
Aaron
Users browsing this forum: No registered users and 27 guests
