It is currently Mon Jul 28, 2025 3:33 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Tue Nov 21, 2006 8:18 am
It gets bloody hot in WA and when you get caught up in bumper to bumper traffic or sitting at Macca's drive thru,waiting for that macflurry,then you do need that extra cooling capacity.Fitting a heatercore behind the grille is a brilliant idea :D
PostPosted: Tue Nov 21, 2006 8:27 am
LS1380, have you fitted a fan behind it for when you are sitting still or is the extra cooling capacity enough?
Rick
PostPosted: Tue Nov 21, 2006 9:00 am
No fan-Just extra clubbie heater core+overflow tank+radiator serviced(remove toptank,rod out tubes,resolder and test+I use Redline Waterwetter.
PostPosted: Tue Nov 21, 2006 9:28 am
Where did you get the Redline water wetter from?? I got some a while back off ebay (which I'm still to use) but it cost a bit including the postage.
For those that don't know this stuff is excellent, helps reduce the temp by reducing the surface tension of the water: http://www.redlineoil.com/products_coolant.asp
A lot of the guys in the US who race use it and they've all said it helps with bringing down the temps a bit.
PostPosted: Tue Nov 21, 2006 9:38 am
I buy it from Coventys(Automotive) Last price I paid was $22.00.
REPCO(Rip Every Poor C... Off) should stock it or any REDLINE stockist.
I also only use distilled water with this-No tap water!!
 Post subject: REPCO
PostPosted: Tue Nov 21, 2006 6:07 pm
Ahhh yes, I've heard that one...REPCO(Rip Every Poor Customer Off) :roll:
PostPosted: Tue Nov 21, 2006 8:47 pm
Get some real HP and then see how well your cooling system goes, I say great idea the ol' heater core. :P :P :P :lol:
Hmm, now where can I fit mine with all these other "radiators"....
Daniel
