It is currently Tue Jul 29, 2025 7:58 am
 Post subject: Idler bearing removal
PostPosted: Wed Nov 22, 2006 7:55 pm
Any easy way or trick to doing this or do I need a special tool for the job ?
PostPosted: Wed Nov 22, 2006 8:18 pm
I presume you're referring to one in the flywheel housing! There is a proper puller that will do the job and most Mini specialist workshops will carry it. Other methods include removing the rollers and cutting the casing through with a dremel tool, or if it's not too tight try filling the bearing up with a heavy grease like that used for wheel bearings, and tap the idler gear shaft into the grease-filled bearing with a soft hammer. The grease will push the bearing out - it's worked occasionally for me.
Curly
PostPosted: Wed Nov 22, 2006 9:09 pm
I use a method passed down to me by a couple of nice old Mini repairers who used to run Telltune (Seven Hills).
I take a 3/8" bolt, position it so the head is just inside the idler bearing, and give it 6 or 8 quick tack weldss with the MIG.
Then I put an 850 diff drive flange over it, fit a nut and washer and wind it out.
You are going to bin the bearing anyway, so no matter it now has a bolt attached.
But being a skinflint I grind the bearing off the bolt, & save bolt for next time! :P
To remove the other idler one in the gearbox casing, I use a piece of 1/2" threaded rod, some nuts and my socket selection.
After I get those 2 circlips out... :wink:
PostPosted: Wed Nov 22, 2006 9:59 pm
Timely - I'll be doing that at the weekend - does it have to be MIG or can a stick do the job?
David L
PostPosted: Wed Nov 22, 2006 10:03 pm
MIG. :)
Arc weld it and you'll blow the bearing shell away, and burn the housing.... :cry:
Users browsing this forum: Bing [Bot], goodie and 67 guests
