It is currently Wed Aug 06, 2025 5:03 pm
 Post subject: Cooper 998 head
PostPosted: Sat Nov 25, 2006 2:52 pm
Hey guys
I was just wondering what price a 12GG295, 998cc Cooper head would go for??
PostPosted: Sat Nov 25, 2006 2:53 pm
I just paid $400 for one
Matt
PostPosted: Sat Nov 25, 2006 3:03 pm
What condition was that in??
PostPosted: Sat Nov 25, 2006 3:08 pm
It is in near perfect condition.
New valves, valve seats etc
It has some mild head work but nothing dramatic
Hope that helps
Matt
PostPosted: Sat Nov 25, 2006 3:10 pm
I sold one about two years ago for about the same money $400
It has been freshly reco'd - that is ; skimmed, unleaded exhaust seats, new guides and one new valve. All the valve seats were recut and ground. That cost me $250 to have done and I paid about $100 for the original head.
Base your selling price on about $400 for a good head. For not much more (give or take maybe three hundred- mostly give) you can have a worked 12G202 from just about any head developer - just as a guide
whats the difference between a cooper 998 head and a standard 998 head?
PostPosted: Sat Nov 25, 2006 3:12 pm
The 998 cooper was a head designed for a 1100, they are more rare, and are the best standard head for 998's or 1100's. I believe
PostPosted: Sat Nov 25, 2006 3:14 pm
Cheers matt
what do you believe a 998 cooper head is worth if it has de carbonised values, new oil seals??
Cheers guys
PostPosted: Sat Nov 25, 2006 3:16 pm
so what is it that changes the capacity from 998 to 1100?
PostPosted: Sat Nov 25, 2006 3:17 pm
The stroke is 0.296" longer on the 1098. Same bore and rods. Piston deck height shorter by 0.148" on the 1098.
edit> typo
Last edited by drmini in aust on Sat Nov 25, 2006 4:26 pm, edited 1 time in total.
PostPosted: Sat Nov 25, 2006 3:18 pm
Sorry
I don't know, i will have a look in Vizards book when I can find it.
cheers. I'm slowly learning
PostPosted: Sat Nov 25, 2006 3:19 pm
An ordinary 998 head is usually a 12G202 head that is very functional but pretty basic in terms of gas flow and gas burning characteristics. The valves are relatively small and restrictive in terms of fuel mixture in and out. But its a head that has lots of spare metal and lends itself to head modifications fairly well.
The 12G295 is a head designed for the more sportysmall bore type A series (Coopers, MG1100s and some sprite/midgets) It has a much better combustion chamber design, bigger valves, better ports and usually uprated valve springs.
It (12G295 head) alone gives a healthy increase in performance on any A series motor but when matched with a sporting camshaft, better carburation and extractors can really make a quick little car.
PostPosted: Sat Nov 25, 2006 3:20 pm
so what would the difference in Kw or bhp be between a stock 998 and a stock 1098? roughly.
PostPosted: Sat Nov 25, 2006 3:23 pm
thanks for all the info. So i would probably be better off getting a 12G295 rather than having my 12G202 modified?
Users browsing this forum: Bing [Bot] and 75 guests
