It is currently Wed Aug 13, 2025 9:08 am
 Post subject: van windows
PostPosted: Fri Nov 24, 2006 3:43 pm
howdy all,
Just a quick question, I am going to be putting my 74 van on the road so my little brother can drive it. I need to put the side windows back on (they were off when I bought it) and I was wondering if you need a locking strip with the rubber or not? And a rating of difficulty.
The car is 400 km's away so I just can't run out and check and I need to purchase anything i need before I go up there on holidays in 2 weeks.
PS,
if you get a chance melbournians, go check out the Anti-Nowhere League tonight or tomorrow night at The Arthouse Hotel- they are an awesome live act!
off to NT I go
 Post subject: window rubbers
PostPosted: Fri Nov 24, 2006 6:20 pm
A little difficult but new rubbers and a bit of soap makes it possible. No locking strips with side window rubbers.
PostPosted: Fri Nov 24, 2006 10:28 pm
But you can use locking strips if you want to we did and it look great
Steve
PostPosted: Sat Nov 25, 2006 7:32 am
I purchased my ones from Clark Rubber, with the lock strip. (That chrome one above looks great).
I used soapy water and a bit of plastic cable in the track, pull the cable out as the glass slides in. The first one took ages, the second 20 minutes or so.
Two people would make it easier - wet soapy glass and all. The main prob with mine was the sides of the van were a little flexy.
PostPosted: Sat Nov 25, 2006 3:23 pm
yeah the sides of mine seemed a little flexy. Thanks for the advice. Soap, water and patience seems the key.
off to NT I go
PostPosted: Sat Nov 25, 2006 3:45 pm
mine has a locking strip also - in black so i couldnt even tell
they were hard to get off - not sure how they are to get on yet though!
a girlfriend would be cheaper
 Post subject: window fit
PostPosted: Sat Nov 25, 2006 8:07 pm
The window rubber that clark rubber stocks is a generic fit and is narrower than original mini stuff, a good mini part supplier should have the right one, costs a bit more tho. if u want to use a lock strip try to get the tool to fit it, they are impossible without it :x , and very easy if u have one. :D
Users browsing this forum: No registered users and 257 guests
