Mini Mike wrote:
Huh...
Im lost now arbt they all the same? Im guesing smiths never made one for ECUs as there old so whats this magnetic induction type? is this what you use if you run it of the coil or magneto? and the generator type???
Now im totally lost
I have an ecu one installed in my daily driver as we speak. Smiths made them in from about 1974.
The magenetic induction is the type determines rpm from a spinning disk, like an electronic ignition or speedo.
The generator type has a generator connected to a cam. The voltage ouptput determines the the rpm shown. Eg each .5v = 500rpm so 12v=6000rpm etc.
I also forgot the square wave ones that run off the coil/ei.
I have had all of them intstalled in different cars through the years.
Just make sure you get one of the correct type for your car.
