It is currently Mon Jul 21, 2025 5:49 pm
PostPosted: Wed Nov 01, 2006 7:48 pm
BIG sockets in 3/4 drive are real strong no matter where they are made.
You won't bust em.
Even the Chinese ones... :lol:
I have two busted Minimax ¾ drive sockets and a Sidchrome ¾ drive ratchet to prove you wrong! :lol: :lol: :lol:
Mind you I also a 6' of 3" water pipe that slips nicely over the handle of the ratchet. :wink:
PostPosted: Wed Nov 01, 2006 8:15 pm
OK you win. But most Chinese biggies now look pretty good.
I use 6ft of water pipe too, for pinion nut- but NEVER on a ratchet... :lol:
PostPosted: Wed Nov 01, 2006 8:28 pm
Wombat I bought the Kokon brand supposed to be a good brand
33mm or 34mm ones should work as well.
PostPosted: Thu Nov 02, 2006 10:15 am
I got a half-inch drive 1 and 5/16" sidcrome socket for $10 from a second hand tool shop near my place, and I think it was new (they sell new tools too) :D
PostPosted: Thu Nov 02, 2006 4:24 pm
It was Ok, it was a Sidchrome ratchet, they supplied new bits and it is as good as new! I have a Kokon ¾ ratchet for most jobs and the Sidchrome for the big jobs and I also have a Warren & Brown ¾ drive tension wrench for all those things that need to be tensioned to 350lb.ft. :lol:
PostPosted: Thu Nov 02, 2006 4:41 pm
Like the nut at the wheel :wink:
David L
PostPosted: Mon Nov 27, 2006 5:28 am
Just to dig this up - which is actually the correct socket for a disk hub nut (metro actually but aren't they the same?) - 1 5/16" or is it 33mm? By my figuring the former is 33.3375mm
Can't get the calipers past the wheel to measure...
PostPosted: Mon Nov 27, 2006 9:07 am
Anybody?
PostPosted: Mon Nov 27, 2006 9:11 am
Yep, same as Mini 8.4"
(so the 1 & 5/16 is correct)
:D
 Post subject: nut size
PostPosted: Mon Nov 27, 2006 10:30 am
I purchased a 3/4 drive 34mm impact socket. (Ebay - US [http://stores.ebay.com.au/1000forless] AU$20 inc. delivery).
Most mini places are only stocking the metric nut version for the disc CVs, as the old 1.5/16's are not being made anymore. Some places may shave it down to fit your old imperial socket, but I suggest buying the metric socket for future-proofing. The 34mm socket will fit both the older 1.5/16 nuts and the newer 34mm nuts. I have been informed the nut is technically a whitworth... but i'm too young for that to mean anything!!!
PostPosted: Mon Nov 27, 2006 10:32 am
Crap....good information that, trouble is I went out at lunch and bought a 1 5/16" :shock:
I guess I'll find out which nuts I have tonight! If I keep it clean they'll swap it I suppose.
 Post subject: Re: nut size
PostPosted: Mon Nov 27, 2006 6:39 pm
I'm a thread hound (tragic, I know...)
It's not a Whitworth thread, it's UNF, but they use 34mm hex bar to make it from because they are made in EU now, not good old GB. :lol:
PostPosted: Tue Nov 28, 2006 1:58 am
For the people in Adelaide, go to "Hong Kong Tools" in Paddy's Markets, Pooraka. Yes, they are as dodgey as they sound.... but they have containers full of these impact sockets in 3/4" drive.... bought mine from there and they worked perfectly.
Alternatiely, you could buy this .......
http://cgi.ebay.com.au/27PCE-COMBINATION-3-4-DR-HEAVY-DUTY-SOCKET-SET-NEW_W0QQitemZ250053916059QQihZ015QQcategoryZ105778QQtcZphotoQQcmdZViewItem
Yes, I bought this kit too 8)
PostPosted: Tue Nov 28, 2006 4:53 am
Well, NZ metro's must have been old school 'cause the 1 5/16" fits nicely :)
PostPosted: Tue Nov 28, 2006 5:45 am
over here you can still get the 1 5/16" nut, allways called "original", if you get one with 34mm its called "nachbau" (not original)
the 34mm is about half the price
Rover 214 atm ....
Users browsing this forum: fuzzy-hair-man and 67 guests
