It is currently Wed Jul 30, 2025 1:54 pm
PostPosted: Tue Nov 28, 2006 9:13 am
This moke on ebay
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... &rd=1&rd=1
When i looked at the photo of the engine - the space between the thermostat housing and the rocker cover, the breather behind the block and other things, I wondered if this is actually a 1.3 as stated in the advert.
I sent a mesage to the advertiser asking what the engine number was and a short explanation of how the engine number prefix gives an indication of the engine size. The advertiser has apparently decline to respond.
What do others think of the engine. ??
I can accept innocent ignorance of mini mecanicals but I dont like blatant deception particularly when its starting attract fairly serious money from buyers who are probably not mini literate.
Comments ???
PostPosted: Tue Nov 28, 2006 11:49 am
agreed.... it's not a 1275, I sent the seller a message too....
PostPosted: Tue Nov 28, 2006 12:23 pm
Definately not a 1275. Since I've just got a 1275 to transplant into my moke i can see the differences.
The motor has the same configuration as my 998. Breather is in the same position. The heater tap is not at an agle like on a 1275 head and there aren't the extra nuts visible near the heater tap that secure the head down. So its a 998 or 1100.
Seen a lot of people putting "californian" in their add headings. Certainly caused a few people grief when they've bought on the sole information of pictures and another persons word !!
Buyer beware !!
TasTyger
PostPosted: Tue Nov 28, 2006 12:33 pm
Will you also send the seller a message (simply modify your post slightly) as I have come to believe this seller is quite aware that this is not a 1275 because of the lack of response to mine and various other messages and it therefore becomes deception.
PostPosted: Tue Nov 28, 2006 12:39 pm
That dosnt really mean that its not a 1275, only the cooper S 1275 came out with 11 head studs standard. Non Cooper S 1275's still only had 9 studs.
PostPosted: Tue Nov 28, 2006 1:29 pm
Going by the angle of the thermostat housing, its air pump mount, and the head's air injection ports, and heater outlet angle, it's a late 998.
NOT a 1275 head. :wink:
PostPosted: Tue Nov 28, 2006 2:11 pm
hanra - totally agree about the number of studs but there are other indications that this motor that is fitted is not a 1275. Non cooper 1275 blocks did not have provison for tappet cover breathers. Simply no tappet covers.
From the engine bay photos it definately looks like the moke is a 1275 (Engine steady design etc) but the engine fitted is not a 1275.
PostPosted: Tue Nov 28, 2006 2:32 pm
Still only "learning" so I don't know all the ins and outs about heads so these sorts of things are a good experience.
The engine steady arrangement and thermostat housing are identical to mine as it is at the moment and its exactly like Doc called it a late version 998....
TT :)
PostPosted: Tue Nov 28, 2006 8:48 pm
i hate dodgey people
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Tue Nov 28, 2006 8:53 pm
I have no proof this person is dodgey - just that a number of things arn't adding up.
He/she may well be dead straight, not mini literate and unable to respond to the many messages to them.
PostPosted: Tue Nov 28, 2006 9:00 pm
i had a good look at that photo and i reckon the thermo cover is just sitting there, with pressure from the rad would it tilt in or out,
PostPosted: Tue Nov 28, 2006 9:22 pm
They have put a comment on the bottom of the add saying its not a 1275.
PostPosted: Tue Nov 28, 2006 9:29 pm
okay then the person is honest - I am pleased.
The sale can proceed without any disapointment at the end of the auction.
case closed !!!
Users browsing this forum: Barkfast and 95 guests
