It is currently Sat Aug 16, 2025 9:25 am
PostPosted: Sat Jan 07, 2006 10:56 am
gafmo wrote:
Nice work thier :wink: I think you were luck thier as your Brake fluid was very Low.. :shock: 8)
Also by the colour of your Brake Fluid,I would strongly suggest you do a brake fluid flush(ie get the old brake fluid out of your wheel cylinders,where condensation sets in and pits out your wheel cylinders and master cylinder)This is usally the reason why wheel cylinders leak.Flushing your Brake System should be carried out every two years.
Maybe also stick to AF and not metric when working on your Mini,less burred sump plugs and other bolts and nuts. :)
PostPosted: Sat Jan 07, 2006 4:31 pm
yeah whats the size for the sump plug in imperial?
i don't think i have that size
don't worry i got plenty of stuff left to service on my car :D
PostPosted: Sat Jan 07, 2006 6:15 pm
DO NOT USE METRIC SPANNERS/SOCKETS ON IMPERIAL BOLTS/NUTS :x :x :x
PostPosted: Sat Jan 07, 2006 8:02 pm
how bout don't use metric bolts and nuts on a mini heh
nothing wrong with using metric on imperial just so long as it fits correctly
PostPosted: Sat Jan 07, 2006 8:35 pm
I agree with willy there.. Use the right tools.. makes things alot easier.
Also you can get stubbon oil filters off with vice grips most of the time.. not as messy as stabbing it with a screw driver.
PostPosted: Sun Jan 15, 2006 11:35 am
Slow-Po
Is this thread going into the "How to" section? 8)
PostPosted: Sun Jan 15, 2006 12:11 pm
don't forget every oil and filter change to grease your nipples (suspension points) this will take a mini garage like 15 minutes so it will be cheap, or if you have a grease gun and a workshop manual...
PostPosted: Sun Jan 15, 2006 3:50 pm
Nice work Spaceboy!! :D
Can I request a few more of these 'how to' things graduallly moving up to replacing windscreen wiper motors, accelerator cables and the like.
Then one day I might be able to keep up with the threads on changing pistons/gearboxs/electricals etc. :?
Cheers! :D
MACK- '78 998 Leyland moke. Full Running Gear Rebuild Complete.
Apparently "Life's Short"- Have YOU done anything that took longer?
PostPosted: Sun Jan 15, 2006 4:48 pm
Speedy's Rule #1- Dont do an oil change in a good white T-shirt!
:lol: :lol: :lol:
He's covered in oil :lol: :lol:
PostPosted: Sun Jan 15, 2006 4:52 pm
hahah how'd he manage that?
PostPosted: Sun Jan 15, 2006 6:30 pm
Slow-Po
:oops: The oil filter was just asking to be stabbed by a screwdriver - its the only way the bloody mongrel was coming off. :x It was worth it though, the new Castrol Formula R non synthetic has made a noticable difference, both engine and gearbox feel smoother once its warm.
Thanks for your help Chop, I would have chucked a wobbly if you weren't there! :)
PostPosted: Sun Jan 15, 2006 7:23 pm
No worries, you had me scared the way you were stabbing that oil filter with oil splattering everywhere, thought better keep on your good side :wink:
was cool fun, but gee you cant fit much more in those rover engine bays
PostPosted: Fri Dec 01, 2006 7:01 pm
bump
Users browsing this forum: No registered users and 298 guests
