It is currently Sun Aug 17, 2025 6:12 pm
 Post subject: brake lines
PostPosted: Fri Dec 01, 2006 9:29 pm
herro
I got stung 20beans for a brake line that goes from the junction to the subframe and to the pass side wheel. Is this fair? the thing is i need both first lines on the clutch and brake. Should I look around or just go back?
Cheers guys and gals
blokeinamoke wrote:
PostPosted: Fri Dec 01, 2006 9:53 pm
I would rather fit new pipes than 30+ year old, if you are doing it properly.
PostPosted: Fri Dec 01, 2006 9:55 pm
High heel ninja
If it was a new peice of pipe flared & with new nuts, i'd call it a bargain, i know mini spares still have brand new original leyland stock subframe brake pipes for around $30 each.
Doogie
PostPosted: Fri Dec 01, 2006 9:59 pm
Stung..as in...did..Nar :wink:
PostPosted: Fri Dec 01, 2006 10:31 pm
I paid $23, 2 years ago for a new front pipe at B&R Brakes.
Take your old ones to a decent brake shop, they have all the gear and fittings to make them properly.
Fittings are copper plated too, so won't rust for a while... :lol:
PostPosted: Fri Dec 01, 2006 11:51 pm
I paid $5 for the same, but supplied the fittings.
