It is currently Wed Jul 30, 2025 1:54 pm
 Post subject: Cam Followers
PostPosted: Wed Dec 20, 2006 4:18 pm
With or without hole or lightened without hole? The last two are double the price of plain. So what do you use?
Edit : just read the fine print in the MS site - the lightened ones have a drain hole :oops:
David L
PostPosted: Wed Dec 20, 2006 4:25 pm
parently there are some that are just plain shite. Isky type lightened ones are the
ones that i am getting for my engine.
PostPosted: Wed Dec 20, 2006 5:37 pm
I've got a set of Minisapres lightened and drilled followers here that I took out after 30 thousand miles. Parts of the machined surface has been shattered off the face of the followers in all but 2 of the 8. It was fitted to a standard Mk2 Cam, now it's got an RE13 cam and I shelled out for another brand of followers.
The MS followers were purchased in 1997.
PostPosted: Wed Dec 20, 2006 6:06 pm
As said, there are some dodgeys around. Reputedly Product of India.
IF they came from MSC they should be OK.
GR recommends getting either the Isky ones (1/8" longer) or the MSC lightened ones.
Whether has hole or not, doesn't really matter.....
:wink:
Users browsing this forum: Barkfast and 98 guests
