It is currently Sun Aug 10, 2025 4:52 am
 Post subject: Brake squeaking any idea
PostPosted: Thu Dec 21, 2006 10:57 am
i just got a brake booster fitted to the car but it squeaks in the morning when the car is cold is that normal?? i have disc brakes.
thansk
1967 Morris Mini Minor - 1380 cc 45mm weber, leather interior, MP3 player with 4' Kicker spits alpine 6x9 and 10in JL sub and Kicker 4 channel amp.
PostPosted: Thu Dec 21, 2006 11:35 am
the brake booster squeeks or the disk rotors? if its the disk rotors its normal. crystalisation (???) builds up over night.to wear it back to normal i just drive along in 2nd, left foot on the brake until the noise stops.
PostPosted: Thu Dec 21, 2006 4:26 pm
when do the brakes squeel? under heavy load or all the time?
Brake squeal
1. Worn retaining pins (disc). --->>> Fit new pins.
2. Faulty damping shims or shoe retaining clips. --->>> Fit new shims or clips.
3. Dust in drum. --->>> Remove dust from drums and shoe.
4. Loose backplate or calliper. --->>> Tighten calliper or backplate.
PostPosted: Thu Dec 21, 2006 6:56 pm
check your brake booster the factory issued mouse may still be inside.
With great power comes great responsibility. It also comes with one kick ass ride.
