It is currently Fri Aug 15, 2025 6:07 am
PostPosted: Thu Jan 04, 2007 11:11 am
As per title - how to remove the spot welded vent on the drivers side?
I just have to drill the spot welds out right? Anyone had luck with a normal drill bit or do I have to get a spot weld remover bit? What diameter?
PostPosted: Thu Jan 04, 2007 11:17 am
A spot weld drill bit is the best mate as it only realy leaves a flat drill mark, not a tapered point like a normal drill bit.. But a normal drill bit is ok just have to be a little more carfull thats all . Start of with a small drill and work your way up to one that is just bigger then the spot weld.....
Mike
If it cant be fixed with a hammer it cant be FIXED!!
PostPosted: Thu Jan 04, 2007 11:38 am
I used Mr Anglegrinder... 8)
PostPosted: Thu Jan 04, 2007 11:45 am
but just driling the welds out should work right?
PostPosted: Thu Jan 04, 2007 11:53 am
aslong as you get all the weld it should. Just slide a chisel or something underneath it after drilling the welds to prise it off. Its been there for years it might take some encoragment
PostPosted: Thu Jan 04, 2007 12:04 pm
After drilling the spotwelds out I'm pretty sure I had to cut or bend the vent box to manouevre it out between the upper and lower rails of the dash.
Yes, use a spotweld bit if possible.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Jan 04, 2007 12:10 pm
Mike
I flattened a normal drill bit and it works a treat on the spotwelds I've been doing - basically just reduced the angle of the cutting edge on my bench grinder ;)
PostPosted: Thu Jan 04, 2007 1:25 pm
Is this demister vent normally on deluxe shells? Coz I have one on mine, looks factory of sorts.
Sounds like your on the ight track then.
Keep us posted
PostPosted: Thu Jan 04, 2007 2:16 pm
They were on most 850s, also all Deluxe, Mini K, MiniMatic- basically all non-cooper roundnose. :wink:
Back then only the Cooper & S got a real heater standard, the rest of use froze- unless you got the freshair one as an option.
MiniMatic had this standard, to help cool the motor. 8)
PostPosted: Fri Jan 05, 2007 5:09 am
Ok thanks everyone - I'll post as I go along.
Users browsing this forum: Bing [Bot] and 265 guests
