Bob, in my opinion leave the radiator & virtually everything on the engine, jack up the car & put stands under it,
take off the front wheels
Disconnet the battery
Take off the bonnet & grill & panel
Take off the air filter & neck off the carb/carbies
Discoonet the wiring,heater hoses,fuel lines,slave cylinder & engine stady/steadies & earth strap & battery cable at the solenoid
Disconnet the exhaust
Put it into reverse & knock the roll pin out of the gear selector & unbolt the selector
Undo the top ball joints & tie rod ends
Pop & break the taper on the ball joint & tie rods, with either a ball joint breaker or hitting it with 2 big hammers
Lay the hubs over till the pot joints pop out
Undo the engine mount bolts
Lift out engine, undo the speedo cable when you have clearence
Anywhere between 1/2 hour & a day you should have a engine out that looks similar to this.
In my opinion leave the radiator on, the time it takes to contort yourself around getting it out is the time it takes to remove the engine, this is how i do it, but i've done it more times than i can remember,.
Doogie
